Old 11-24-2013, 08:58 AM   #1
jabingb
Drives: Hot Lava automatic FR-S
2014 stock head HDMI input
Would like to find a way to feed the HDMI output from my android phone to the stock head for GPS app display. Would the harness for the Beatsonic rear camera assist with this, doubt it? The other catch is that this is a leased car so I don't want it to be too invasive.
jabingb is offline   Reply With Quote
Old 11-24-2013, 09:46 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
You'll need a new headunit. The OEM headunit will not have provisions for HDMI. At all. Ever.
infinite012 is offline   Reply With Quote
Old 11-24-2013, 10:11 AM   #3
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
This is as close as you'll get: http://www.ft86club.com/forums/showthread.php?t=49633
It isn't great.
robot is offline   Reply With Quote
Old 11-24-2013, 06:08 PM   #4
jabingb
Thanks for that link, pretty much quashes that idea!
Old 12-09-2014, 09:59 PM   #5
Beat-Sonic
Beat-Sonic's Avatar
Drives: Toyota and Lexus
There is actually a separate Video Input provision for the Scion headunits that Subaru BRZ does not have.
Although, it is not an HDMI input and uses RCA cables, you may convert the HDMI from the smartphones to RCA and make it work.
Here is the product to activate the video input. It will add a new menu item on your touch screen called "VTR"
http://www.beatsonicusa.com/avc39.html
You will also need the TVK-61 to tell the headunit that the parking brake is connected and engaged. From the factory, there is no wire telling the headunit about the state of the parking brake. Without this, the screen will only show black.
http://www.beatsonicusa.com/beatsonic-tvk-61.html
Now, the headunit is ready to take a video to show on the screen. Depending on what you will be feeding into the headunit (video, audio or both) what you will need will differ.
For example,
To mirrior your iphone 5 or 6,
You will also need:
http://www.beatsonicusa.com/if16.html
[ame="http://www.amazon.com/Apple-MD826ZM-Lightning-Digital-Adapter/dp/B009WHV3BM/ref=sr_1_1?ie=UTF8&qid=1411460069&sr=8-1&keywords=lightning+cable+to+hdmi"]Amazon.com : Lightning Digital AV Adapter : MP3 Players & Accessories[/ame]
[ame="http://www.amazon.com/AmazonBasics-High-Speed-HDMI-Cable-Supports/dp/B00870ZHCQ/ref=sr_1_4?ie=UTF8&qid=1411460128&sr=8-4&keywords=hdmi"]Amazon.com: AmazonBasics High-Speed HDMI Cable - 3 Feet (0.9 Meters) Supports Ethernet, 3D, and Audio Return: Electronics[/ame]
[ame="http://www.amazon.com/Raptor-R5RCAMM-Male-Audio-Interconnects/dp/B00EN86JEG/ref=sr_1_3?s=electronics&ie=UTF8&qid=1411460219&sr =1-3&keywords=rca+male+to+male"]Amazon.com : Raptor R5RCAMM RCA Pro Series Male to Male Audio Interconnects : Vehicle Amplifier Stereo Patch Cables : Electronics[/ame]
By doing the above instead of using the backup camera video input to show video, you will not see the "Check Surrounding before Backing Up" message on the bottom and you will also be able to feed Audio. In addition, you can chose the video input option from the headunit's menu.
Beat-Sonic is offline   Reply With Quote
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 06:24 PM
2013 FR-S with 2014 Head Unit Exorcized Electronics | Audio | NAV | Infotainment 5 09-09-2013 02:12 PM
2014 MY head unit details? watts? Pablitomarrero Electronics | Audio | NAV | Infotainment 1 06-17-2013 08:38 PM
