Old 11-23-2013, 10:14 PM   #1
mrdanyo
Drives: 2014 BRZ Limited (World Rally Blue)
HELP! Rear view camera on 2014 Canadian BRZ.
Trying to get a rear view cam installed on my 2014 Canadian BRZ but they switched the head unit from Pioneer to a Subie branded one. I'm not sure what wires I'm gonna need to do the install, so if anyone else has done this on a 2014 Canadian BRZ... please share!
Thanks!
mrdanyo is offline   Reply With Quote
Old 01-12-2014, 06:23 PM   #2
mrdanyo
Still trying to figure this one out. Anyone have any luck?
Old 01-12-2014, 07:50 PM   #3
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Check out this thread;
http://www.ft86club.com/forums/showt...ght=rydeen+duo
#944_10_Series_FRS is offline   Reply With Quote
Old 01-15-2014, 12:27 AM   #4
mrdanyo
Originally Posted by #944_10_Series_FRS View Post
I've seen pretty much all the threads, but I've been told from the guys at my shop that because of the new unit in 2014s, it's not the same. They don't know which wires to use for the Canadian 2014s yet.
Old 01-15-2014, 11:47 PM   #5
lightdir
Drives: 2013 Raven FRS 6MT
you might hit up the user postbreak . i know he has a backup camera hooked up to the 2014 model radio
lightdir is offline   Reply With Quote
Old 01-16-2014, 12:48 AM   #6
starbot
Drives: Beep Beep
I installed a Rydeen Duo to my 2014 HU. If it's the same Fujitsu unit as the US models, then you can connect to the HU with the wire harness from http://ae64.com/Rear-camera-16-pin.htm
starbot is offline   Reply With Quote
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
BRZ rear view (Back-up) Camera questions cslntuee Electronics | Audio | NAV | Infotainment 1 09-25-2013 01:43 PM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke with rear view camera harness fs xpicer Audio/Visual, Electronics, Infotainment, NAV 1 11-25-2012 02:35 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
