Old 11-21-2013, 02:30 PM   #1
Necric
Want to install Nexus 7 as head unit....does this cable exist?
Drove to the custom audio place down the street and talked to a rep about installing my tablet in place of the OEM head unit.
He told me he just installed one in a Jeep not too long ago, and that the guy had a Micro Usb cable that carried Audio + Power/Ground. However I can't seem to find one and the only ones I have seen are spliced together. Does anyone know where I can find one, or if it even exists?
It's either this route or buying an smaller additional head unit to sit behind it. But that's more $$$
Necric is offline   Reply With Quote
Old 11-21-2013, 03:09 PM   #2
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
Hows about something like this?
http://www.newegg.com/Product/Produc...131121200819:s
microbionic is offline   Reply With Quote
Old 11-21-2013, 03:19 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
so you want to completely remove the oem head unit and install the tablet in place of it, right?
a usb cable just carries data and power-- charging it isn't a problem, but you would require some sort of hideaway module that can get the audio data and convert it to an analog form that would then go out to an amp of some sort, and then the speakers(i don't have an 86 yet, so i don't remember if they have a factory amp)
Old 11-21-2013, 03:26 PM   #4
Necric
It does come with factory amp.
Door speakers not working after new head unit install lsr78 Electronics | Audio | NAV | Infotainment 17 04-27-2021 04:23 PM
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
Another Nexus 7 install: Clean and Easy Sojhinn Electronics | Audio | NAV | Infotainment 264 10-30-2015 08:26 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Messaging on BRZ Head Unit with Galaxy Nexus? Foobar Electronics | Audio | NAV | Infotainment 0 08-30-2012 09:13 AM
