Old 11-20-2013, 10:46 AM   #1
riironman
riironman's Avatar
Drives: asphalt fr-s
rims dont fit over hub
What size and type of wheel spacers do I need to fit my rims. My new rims hub opening is only 2" and our inner hub circle and oem rim opening is about 2 1/4. I want the rims to sit flush against the hub.
riironman is offline   Reply With Quote
Old 11-20-2013, 10:52 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
This is confusing, you lowered it and now want or need spacers? You bought different wheels and now need hubcentric rings? Sorry not clear on what you are asking help for here exactly....
Old 11-20-2013, 10:58 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
He is talking about the center bore of his wheel.
Old 11-20-2013, 11:45 AM   #4
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
what wheels did you buy?
shiumai is offline   Reply With Quote
Old 11-20-2013, 12:23 PM   #5
riironman
riironman's Avatar
I bought 19" inch trd rims. They were off a scion tc. Lug spacing in 5x100 but when I go to mount it rocks on my center hub. The center bore of the rim is a little too small
Old 11-20-2013, 12:34 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Yep, those are a 54mm center bore, our cars are 56.1mm. You'll need to take them to a machine shop and have them enlarged slightly if you want to use them.
Originally Posted by humfrz
I'm old and lazy
Old 11-20-2013, 01:16 PM   #7
riironman
riironman's Avatar
So spacers wont work? Or will eat up too much lug thread?
Old 11-20-2013, 01:21 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you must use these wheels, you'll need a minimum 10mm spacer. Which means one of two choices:
1) extended studs
2) bolt-on spacers (usually min. 15mm)
This is also assuming your wheels have the proper holes for the studs/lugs to pass through. If you're not sure about this or don't know what I'm talking about, just get rid of the wheels and save yourself the trouble......... unless you got the wheels for free. At which point I'd just resell them to a tC guy and get a decent set of wheels that actually fit the car.
-alex
Old 11-20-2013, 01:22 PM   #9
diss7
Drives: AE86, 2x GT86, TE27
Just take it to a machining/engineering place.
They'll most likely do it for cash/beers/blowy
diss7 is offline   Reply With Quote
Old 11-20-2013, 01:32 PM   #10
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
+1
Shouldn't be too expensive either.
Redstar is offline   Reply With Quote
Old 11-20-2013, 01:40 PM   #11
mav1178
mav1178's Avatar
Originally Posted by Redstar View Post
+1
My only advice against this is that some wheels are designed for specific center bores, and removing material around it may reduce structural integrity of the whee.
It most likely won't be an issue with heavy OEM-type wheels, but just FYI.
-alex
Old 11-20-2013, 01:43 PM   #12
riironman
riironman's Avatar
Thank you. I will try to find a machine shop.
Old 11-20-2013, 01:43 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The only way the rims are going to sit flush against the hubs are going to be to take them to a machine shop to have them open up the bore. I wouldn't worry about shaving a couple mils off the diamteter. I don't see it hurting the structural integrity of the wheel. I would rather do that and keep them hub centric then run a set of non hubcentric spacers and the wheels on top of that.
Old 11-20-2013, 01:58 PM   #14
Redstar
Destroyer of Tires
Redstar's Avatar
-alex
Machining the center bore 2.1mm larger is fine. I work for a wheel manufacturer, and we regularly bore out wheels from 57.1mm all the way up to 74.1mm.
After all that, I still dont know LS13 Scion FR-S / Toyota 86 GT86 General Forum 35 04-01-2013 05:15 PM
We dont need e85 in oz. We have r100! invisage Scion FR-S / Toyota 86 GT86 General Forum 9 01-09-2013 05:10 PM
Just dont want any problems! youcantseeme24 Engine, Exhaust, Transmission 50 11-25-2012 07:53 PM
dont hate me for asking.. weight? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 27 03-08-2012 02:09 PM
