Old 11-18-2013, 06:35 PM   #1
Cahue
Cahue's Avatar
Is there any auto alarm that works with the BRZ (limited)
Not sure if this has been asked before and it's kind if hard to navigate the forum through my phone.
I have a friend who installs security alarm and remote starts. He said the viper Alarms have no current module for the brz due to the remote start. He said he can give the alarm a try but didn't guarante it. Has anybody secesufully installed a security alarm? If so, what brand and model of alarm? Also was it in a premium, limited or scion?
Cahue is offline   Reply With Quote
Old 11-18-2013, 06:39 PM   #2
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
Not that Ive found. Im waiting for FlashLogic to release a flash for the keyless entry and start so I can use a Viper remote start and security.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 11-18-2013, 07:49 PM   #3
kuhlka
Drives: 2013 BRZ Limited AT
In the meantime, did you enable the factory alarm?
1. Turn the ignition to ON (all lights light up, but car isn't running, two presses of the button)
2. Press the lock button on the driver's door.
3. Press the unlock button on the driver's door and hold it. Open the door and wait 10 seconds while holding the unlock button.
4. The car's horn should beep and either "AL on" or "AL off" will display on the dash.
If you want to test the alarm, roll your car's windows down. Take your fob about 20 feet away (leave it in the house out of range of the sensor). Lock the car using the fob. Set it down. Walk over to the car and use the physical unlock button or switch on the door to unlock it. When you open the door, the alarm will go off. Sprint back to your fob before your neighbors get pissed.
kuhlka is offline   Reply With Quote
The Following 2 Users Say Thank You to kuhlka For This Useful Post:
andrew (11-18-2013), tr1x5tuh (12-14-2013)
Old 11-18-2013, 08:08 PM   #4
Cahue
Cahue's Avatar
Thanks.. That actually sounds good. Is there a ETA for the release?
Old 11-18-2013, 08:11 PM   #5
Cahue
Cahue's Avatar
Thanks.. Already done. Just sucks leaving the car unprotected with all the goodies on.
Old 12-11-2013, 07:13 PM   #6
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah, sucks. Been waiting for over a year now. One place locally said I should check back in 3 months...
Old 12-13-2013, 06:27 AM   #7
Zippy
Drives: 2013 Subaru BRZ WRB AT
I have a compustar on my BRZ limited. The installer even got it to work through the factory keyfob instead of an after market. I can arm and disarm the alarm by pressing the door handle locations and opening the trunk disables the alarm. When I lock the doors through the fob the alarm engages. Only real drawback is I do not have the half mile range of an after market two way. I'm fine with that though.
Zippy is offline   Reply With Quote
Old 12-13-2013, 06:36 AM   #8
arashishozen
Guest
Posts: n/a
Does this work for the frs?
Old 12-13-2013, 10:44 AM   #9
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Since you don't have a 1-mile range unit, could you divulge which ones was installed for your car? This would be better than nothing! I'm not looking for a lot of distance. I'm generally fairly close to my BRZ, not even 20 feet away at home and barely 100 feet away at work.
From my work window:
In my backyard just a few feet away from the side of the house:
Still sucks to run out and start it when it's below freezing!
Old 12-14-2013, 01:05 PM   #10
kuhlka
Try it. I bet it does.
Old 12-14-2013, 01:11 PM   #11
s2d4
s2d4's Avatar
http://www.kiramek.com/english/produ...iborg/540.html
The Following User Says Thank You to s2d4 For This Useful Post:
Trap63 (12-17-2013)
Old 12-14-2013, 01:44 PM   #12
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
No, only the brz limited has this feature.
cjsporl1996 is offline   Reply With Quote
Old 12-16-2013, 09:53 PM   #13
dnieves
Drives: FR-S 10 Series
The FRS 10 Series has it (tested it on mine too) -most likely the FR-S Monogram edition will as well.
dnieves is offline   Reply With Quote
Old 12-17-2013, 12:05 PM   #14
cjsporl1996
Thanks, I forgot that the special edition and the monogram series had it. I must be thinking of the old days when the brz limited had all the extra features.
The Following User Says Thank You to cjsporl1996 For This Useful Post:
chanomatik (12-17-2013)
How to activate brz limited alarm Lee358 DIY (Do-It-Yourself) Guides 129 05-17-2024 08:21 AM
Alarm System on the Limited Smokinbuffalo BRZ First-Gen (2012+) — General Topics 10 05-29-2015 10:17 PM
after market alarm on brz limited three3y3wrbbrz Electronics | Audio | NAV | Infotainment 2 08-05-2014 01:52 AM
