Old 11-12-2013, 01:31 PM   #1
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Ferrea Products on FI FA20
Is anyone who is boosted using their valvetrain parts?
Darryljr11 is offline   Reply With Quote
Old 11-12-2013, 02:06 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't know of anyone with a currently running engine that is using them. I know they have been used in a couple builds though.
Old 11-12-2013, 02:13 PM   #3
Frs300
Frs300's Avatar
Drives: Pile of junk
My car being one of those builds
Frs300 is offline   Reply With Quote
Old 11-13-2013, 05:55 AM   #4
cf6mech
Drives: FRS Silver LS1 swapped.
My car is up and running with them,....what is your question. I have the race set.
cf6mech is offline   Reply With Quote
Old 11-13-2013, 10:01 AM   #5
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Are you NA or FI? How much boost are you running? Is it appropriate as a daily driver? Who did your build and for how much? How does it effect RPM, idle, and throttle response?
Old 11-13-2013, 10:04 AM   #6
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Do you have the street set or race set?
Old 11-13-2013, 10:08 AM   #7
Frs300
Frs300's Avatar
race
Old 11-13-2013, 11:09 AM   #8
ramiram1984
Drives: 2016 STi DGM
I'm debating whether or not I want to do internals. If only running FI, don't see the need. If pushing tons of HP, then I may see the need.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 11-13-2013, 02:24 PM   #9
cf6mech
I'm FI and at 10psi,...previously at 20 psi. I feel 20 psi in this car is un-usable in that it changes a drivers car into a liability (crazy wheel spin every where on 245 tires). Unless you drag race, which to me defeats the purpose. Its a great DD, the valves are noisy,..you can definitely hear them,...it cured my idle dip problem at idle,.. I do feel its an improvement but the dyno didn't show it....AWD tuning in Flower Mound Texas did my build. Cost wise is irrelevant cause I went overkill in a lot of areas.
Old 11-13-2013, 02:29 PM   #10
CSG David
CSG David's Avatar
Ferrea is one of the best on the market. There is also REV and Supertech as well. I have chatted with Ferrea and will be working with them directly when we have a few engine builds in the future.
Old 11-13-2013, 03:43 PM   #11
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
How are the valves noisy? Do you have an audio clip? Sorry if this is too many questions lol
Old 11-14-2013, 06:06 AM   #12
cf6mech
No Audio clip,...not noisy in a bad sense i.e. annoying ,...but you definitely can hear the difference from stock.
Old 11-14-2013, 09:11 AM   #13
350matt
Drives: toyota mr2/ Toyota GT86
I take it you've got some stronger springs fitted as well as the Ferrea valve?
do you know what laoding / precentage increase these were?
as the valve shouldn't be noisy on its own there must be a higher landing force due to a stronger spring
350matt is offline   Reply With Quote
Old 11-14-2013, 09:25 AM   #14
ft_sjo
Drives: GT86
Noisy valves?
Ferrea's Valve components for FRS/BRZ Sportsguy83 Engine, Exhaust, Transmission 44 05-09-2014 08:46 AM
FS: Ferrea Valves Frs300 Engine, Exhaust, Bolt-Ons 23 01-04-2014 03:28 PM
FA20 or 4U-GSE ??? WesFRS Engine, Exhaust, Transmission 2 04-25-2013 04:17 AM
VM vs FA20 CAi speedtrip Engine, Exhaust, Transmission 0 02-05-2013 12:34 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
