Old 11-11-2013, 11:00 AM   #1
toeout
rear adjustable UCA vs LCA in STX
I want to keep the ride height independent from the camber. UCA's are nearly double the price of LCA's (Racer X ). It seems that both achieve the same thing. What am I missing?
toeout is offline   Reply With Quote
Old 11-11-2013, 11:14 AM   #2
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Just get the lowers and you will be set if that's the route you want to go. I am on the stock ones right now, found that at the camber I wanted, set by ride height, it was where I wanted in height and camber. Just used front camber plates to dial in the rest of the car.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 11-11-2013, 03:15 PM   #3
toeout
I'll hold off on them till the rest suspension is in place and see if they are even needed. I just wondered, in STX context, why anybody would get the upper arms, since they are way more $$$.
DIY: Whiteline Rear Adjustable Toe Arms RallySport Direct DIY (Do-It-Yourself) Guides 1 07-10-2015 09:38 PM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Suggestion For Those With Rear Adjustable Dampers Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-14-2013 10:19 PM
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 10:56 PM
Do Adjustable rear LCA/Camber bushings cause stress? mact Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-16-2013 10:05 AM
