Old 11-11-2013, 01:09 AM   #1
tzhu07
What the hell do car makers NOT put the bottom two screw holes for license plates?
WELL?????
I have a license plate that I attached with double-sided tape on the bottom because the FR-S, like many cars, does not come with the bottom two screw holes.
tzhu07 is offline   Reply With Quote
Old 11-11-2013, 01:12 AM   #2
Tromatic
Does it really need four to hold the thing on?
Old 11-11-2013, 01:14 AM   #3
tzhu07
To simply hold it here? Of course not.
To make it look clean? Yes. A common problem with license plates is that they are warped (due to the thinness of the metal). So if you want a frameless look, you pretty much have to tape the bottom to your car.
Old 11-11-2013, 01:21 AM   #4
Tromatic
Ahh. Although if I was after "clean" I wouldn't use screws at all.
Old 11-11-2013, 01:25 AM   #5
Well, tzhu07, may I suggest you use a strong two sided sticky tape underneith to help support the plate and then superglue two bolts into the bottom holes, to match the top two .... ??
Old 11-11-2013, 11:38 AM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Adds lightness.
You could sandblast the back of the plate to make that lighter too
Old 11-11-2013, 09:05 PM   #7
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
The WeatheTech ClearFrame license plate frame is gasketed to seal the elements off of the face of the license plate. In order to affect a complete seal fasteners are required top and bottom.
http://www.weathertech.com/clearframe/
K2 is offline   Reply With Quote
Old 11-11-2013, 10:01 PM   #8
whataboutbob
AutoX-10/10ths every run
Sound systems can make the plate rattle. I put some padded tape on the backside of the plate for this reason.
Build thread:Here
Old 11-11-2013, 11:33 PM   #9
Tfrase
Tfrase's Avatar
Drives: 2013 FR-S Series 10
I just used double-sided tape on the foam that (I guess?) the dealer installed ... works well... guess I'm lucky enough to have a straight plate.
Tfrase is offline   Reply With Quote
Old 11-12-2013, 01:36 AM   #10
dnieves
Drives: FR-S 10 Series
My moron of a salesman used a drill to screw in my rear license plate and the nylon bushings (?) are stripped. Are there part numbers and a way to pop them out for replacement?
dnieves is offline   Reply With Quote
Old 11-13-2013, 01:43 AM   #11
Bruce125
Bruce125's Avatar
Drives: '13 FR-S Whiteout M/T
I found one of mine was stripped as well when I went to replace the temporary tag with my license plate. The dealer's parts department said it would cost about $7 and they would have to order it. I said why should I have to pay for it when their employee damaged it putting on the temporary tag. They ended up finding a spare one in the service department, popped it in and was good to go.
Bruce125 is offline   Reply With Quote
Plugging up license plate bumper holes? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 10 04-12-2015 03:06 PM
Trunk License Plate plastic holes cracked Wes Issues | Warranty | Recalls / TSB 9 02-21-2013 11:36 PM
No Holes License Plate Review! HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-10-2012 05:44 PM
Bumper Plugs for License Plate holes by dealer? mikeg7827 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-13-2012 05:33 PM
License plate holes - Dealer installed for sure? FastLap Scion FR-S / Toyota 86 GT86 General Forum 28 08-05-2012 03:20 AM
