Old 11-09-2013, 03:50 PM   #1
Blood
Drives: 2018 STI
Springs/coilover recommendations?
I've been reading tons of threads for the past couple hours but haven't gotten any definitive answers on a lot of things, so help me out please!
What I'm looking for:
- Lower the car by 1" on all 4 corners
- Same ride quality as stock, or softer if possible (It is my daily driver)
- Within a $1000 budget, possibly a little more
Options I was looking at:
- Eibach Pro-kit springs + stock shocks/struts
- ST Coilovers
The only issue with the ST coilovers is that I live in a snowy state where roads are salted and I'm not sure how they'll hold up against corrosion. Reviews I read of the Pro-kit springs say they have a slightly harsher ride than stock springs, though I don't know if this is improved by changing shocks/struts.
Some questions:
Are there any other lowering springs that come with new bump stops? Don't really like the idea of cutting the stock ones. (This is why I like the Pro-kit springs).
For a 1" drop, do I need to buy anything in addition to springs / coilovers and getting an alignment?
Thanks for the help and recommendations!
Blood is offline   Reply With Quote
Old 11-09-2013, 04:06 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Bilstein B14 would be good to retain the stock ride quality but a little firmer. It is corrosion resistant, but it's a little over your budget.
JDKane527 is offline   Reply With Quote
Old 11-09-2013, 05:19 PM   #3
Blood
Drives: 2018 STI
I was looking in the sticky thread for springs/coilover options and didn't see these, but just saw the thread about them from FT-86 SpeedFactory after reading your reply. I can probably manage $1500 for these in the spring. I'm open to other options too though.
Will I need new camber bolts or anything else with a 1" drop? Considering going to an 8" wide rim / 235 tire in the rear as well. Staying 7" wide rim / 215 tire in the front.
Old 11-09-2013, 05:49 PM   #4
protpibe
protpibe's Avatar
Unless you have a burning desire to get coilovers, the Pro-Kit fits the bill perfectly. It's a very near stock ride and will give you a 1" drop. Camber bolts certainly wouldn't hurt, and I would definitely suggest an alignment after installing new springs. I would estimate you can have a pro-kit and koni Yellows installed and aligned for under your budget while maintaining ride quality.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Coilover and Springs Install at Performance Shop F-T Mechanical Maintenance and Tools 22 12-12-2013 01:12 PM
Hid i d recommendations? Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 12 11-06-2013 01:26 AM
swift coilover replacement springs 8k pitstops Brakes, Suspension, Chassis 0 06-14-2013 03:36 PM
TEIN COILOVER SPRINGS jammz Brakes, Suspension, Chassis 0 04-01-2013 01:33 AM
