Old 11-02-2013, 02:48 AM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Will 18x9.5 +40 square clear stock struts?
Pretty sure the rear will clear but don't think the front will. Can anyone out there confirm that this or something with even slightly better clearance didn't fit when they tried?
I did a quick search but I should've been asleep an hour ago and can't stay up searching.
Old 11-02-2013, 03:40 AM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
Don't know but +38 did without rubbing and 1" drop and camber at -1.5
SliverBrz is offline   Reply With Quote
Old 11-02-2013, 04:39 AM   #3
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
It will clear even with stock struts, but very close to spring perch. Mine is 5-6 mm away from perch offset + 38. You are dangerously close if u r using stock struts.
Sent from my SGH-T999 using Tapatalk
hanabie is offline   Reply With Quote
Old 11-02-2013, 03:43 PM   #4
jeebus
Drives: 2015 Mustang GT (on order)
I doubt it. I'm running 17x9 +42 (but with 3mm spacers effectively making it +39) and I ended up taking a grinder to my spring seat to add a bit of clearance. I am running camber bolts though, and I realize that makes clearance a tad worse. Without the spacer the tire touched the seat hard enough that the wheel would barely spin when I attempted to do so.
For the record, I'm running 245/40 Rivals.
jeebus is offline   Reply With Quote
Old 11-04-2013, 10:11 AM   #5
manonastick
Drives: WRB ZC6
I have heard stories of people of being able to clear the fronts running 225 on 9.5 on lower springs but its very tight fit
manonastick is offline   Reply With Quote
Old 11-04-2013, 11:14 AM   #6
yohan04
yohan04's Avatar
Drives: Your sister
The wheel itself will clear, but depending on your tire size + camber, there's a risk of rubbing.
yohan04 is offline   Reply With Quote
Old 11-04-2013, 11:28 AM   #7
djdnz
1337
Drives: 2013 BRZ WRB S/C
Depends on tire and camber. In all likely hood with the camber you will want to run at that offset, no.
djdnz is offline   Reply With Quote
Old 11-04-2013, 02:48 PM   #8
switchlanez
Thanks for the replies. I'd be on OEM crash bolts with -1.2 degrees camber and lowered 1.2-1.4 inches. Would likely need coilovers. Is it true the new Bilstein B14 coils have the same spring diameter as stock?
Old 11-04-2013, 03:12 PM   #9
FR-S Matt
No, this will not. That 2MM difference won't clear the stock spring perch in the front. It will rub there but not in the rear.
I ran my RPF1's, 18X9.5 +38 on stock suspension for a while and I could barely get a finger through where the tire almost hit the spring. You'll need small spacers up front if anything.
Old 11-07-2013, 02:42 PM   #10
manonastick
Drives: WRB ZC6
Only solution i have atm if you dont need coils is changing to koni shocks up front and maybe that may clear the struts?
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
18x9.5+44 square vs 18x8.5-18x9.5+44 Beyer Subaru Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 08-20-2013 09:35 PM
Sunlight Silver & Semigloss black Rays 57Xtreme 18x9.5 square setup - IN STOCK! No Limit Motorsport Wheels and Tires 21 05-25-2013 03:42 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
