Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 10-31-2013, 12:46 PM   #1
Moe
Moe's Avatar
Drives: Lexus IS250, Toyota 86
RGM Special
Just noticed that the RGM supercharger kit is on special for R79k including the exhaust (on their website).
What's the consensus on the RGM kit - Worth it? Too expensive?
Moe is offline   Reply With Quote
Old 10-31-2013, 12:54 PM   #2
Moe
Moe's Avatar
Here's the link to their site. It's currently the first item on the page: http://www.rgmotorsport.com/
NB: I'm not affiliated with them in any way by posting their site info.
Old 10-31-2013, 01:44 PM   #3
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
A lot of us can't afford it, me included. That said - it shunts and is a high quality conversion and proving itself on the streets and on the strip. Check out RGM on Facebook for some evidence...
Vic_RSA is offline   Reply With Quote
Old 11-01-2013, 05:56 AM   #4
Fuzz
Drives: '13 Toyota GT86 , VW Chico "1.4"
My biggest gripe with the RGM kit is the fact that they are using the UniQ chip for the ECU.
My experience with Honda's have shown how inferior these products are compared to proper flash tuners. RGM insisted that the UniQ worked and was the best thing for the Honda K-series engines but have since been proven so wrong by Hondata's Flashpro / K-Pro, that no K-series Honda owner now uses the UniQ on their cars.
UniQ vs Flashpro unit for K20 Honda engines. The UniQ could only adjust fueling and timing, but not the continuous variable valve timing and lift which the I-VTec controlled. The Flashpro could not only change where VTec engaged, but by how much the cam angles and valve lift vary at each point of the rev range.
I am sure our FA20 engines will experience the same limitations on the UniQ
Why RGM is not using the EcuTek Flash Tuning unit is beyond me. Flash tuning beats plug and play chips 99.99% of the time.
Oh, and their kit excludes an intercooler and for 80k I would expect one.
Personally, if I was in JHB, I would rather let NxGen Performance work on my car. They are EcuTek agents.
Would be interesting to see a comparative quote from them http://www.nxgen.co.za/
Fuzz is offline   Reply With Quote
Old 11-01-2013, 07:01 AM   #5
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Hi . I just ordered in a Gready Turbo kit and in the process to find a managment system.
I was impressed with ECUTEC and flash tunning and still heading in that direction, but I still struggle to get proper support in Cape Town.
The Master turners in SA are limited and not very flexible. I must say my experience with the local ECUTEC team was not a plesant one (Finding ways to get tunning done form Cape Town ).
So I am still stuck on a my quest to find a management kit option while my Turbo Kit is in shipment.
Jacques Blom is offline   Reply With Quote
Old 11-01-2013, 07:23 AM   #6
Fuzz
Yeah, in CPT there are no real Scooby tuning experts. Heard good thing about GSR with Scooby engines though as well as Pyro Performance but not sure regarding the flash tuning though.
Who do you plan on doing work with on your car.
Old 11-03-2013, 02:41 AM   #7
Jacques Blom
Turbo 86
Build, many cars in my life so mechanical sound just new to the management side of things...did chat with Pyro very helpfull but booked until end December and the Jose from Topend could help me, just checking if they can get the software to work on the flash.
Old 11-03-2013, 05:52 PM   #8
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Pyro Performance are the ecutec agents in CT. They've done a number of scoobies with ecutec in CT.
@Fuzz, the reason RGM went with UniQ instead of ecutec or a full management is because they only need to adjust fuelling & timing.
They are not changing the cams or adjusting the cam timing.
If you were to put in bigger cams or advance the cams, then I'd say yes, go for a more comprehensive management system. But then you would also need to always run octane booster or avgas or perhaps include a water meth kit. Thus the cost would end up much higher. But as the system is, the UniQ more than suffices.
Razzle is offline   Reply With Quote
Old 11-05-2013, 03:36 AM   #9
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
You sure about that?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 11-05-2013, 04:29 AM   #10
Jacques Blom
Turbo 86
To surprise the GTI`s ....... more into track fun day`s.. .
Old 11-05-2013, 04:34 AM   #11
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Nothing better than surprising a GTnaai....... priceless
your kit is taking forever to get here?????
some advise, review your brakes, ensure they are adequate for your extra boost. keep an eye on your clutch too.
Ryan86 is offline   Reply With Quote
Old 11-05-2013, 04:50 AM   #12
Jacques Blom
Turbo 86
Yes -- delay due to some extra stuff ordered from Canada--ML24 body stuff.. brakes , yes part of my plan... clutch --- will see how it goes .. are you going to the 7th track day ? I am working .. bad time slot .. for me .
Special forum coupon - Edit: special has ended, Thanks! bestwheelbase Announcements, Contests, Giveaways 6 10-25-2013 06:30 PM
Halloween special! Unichip Jack Engine, Exhaust, Bolt-Ons 0 10-25-2013 02:08 PM
Lightly Used Innovate Supercharger Setup Install Special! Locals Only Special! Pure Automotive Mid-Atlantic 25 08-27-2013 01:00 PM
ARK Special!!!!! Titanmotorsports Announcements, Contests, Giveaways 30 07-16-2013 06:38 PM
Special Brochure:Special Car tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 0 05-31-2012 12:59 AM
