Old 10-30-2013, 11:52 PM   #1
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Car dead ( electrically )
Well for some reason my car has no electrical power at all. I has tom lights only ( i have a pin cut from one of the lights that i put back in manually and stays in place but i then soldered it temporarily )
Any ideas what it could be ? any fuses that i would need to check or anything else before i tow the car off to a shop or dealership ?
i doubt its the battery because the car does nothing electrical.
Old 10-31-2013, 12:01 AM   #2
Pete156
I like to eat!
What are tom lights? Head lights? Tail Lights? What is soldiering?
Trying to help but you've got me confused
Pete156 is offline   Reply With Quote
Old 10-31-2013, 12:04 AM   #3
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
Toms Tail Lights
Solder: [ame="http://en.wikipedia.org/wiki/Solder"]Solder - Wikipedia, the free encyclopedia[/ame]
I can't really help you though OP
SoCal909 is offline   Reply With Quote
Old 10-31-2013, 12:07 AM   #4
SmsAlSuwaidi
Boosted
sucks that I had to go to a meet and my car just sat there
edit: i remember reading about a guy who did something wrong ( with the toms or something ) and ended up frying a fuse but stated once he found it out it wasnt serious. freaking sucks i cant find the post now.
Old 10-31-2013, 09:21 AM   #5
SmsAlSuwaidi
Boosted
Old 10-31-2013, 10:16 AM   #6
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
No power at all? Like turn key on and nothing? Sounds like a dead battery.
Could be an interior light left on (door / trunk slightly open etc) or the tail light install isn't quiet right and slightly draining your battery.
Nolan
pheoxs is offline   Reply With Quote
Old 10-31-2013, 10:26 AM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Flat battery is the obvious candidate.
Loose battery cable can seem like no power is available. Troubleshooting means starting right there. Grab the ground and twist, then let go and do the same to the positive. No movement should be detectable. Then at the cable ends check for voltage with a multimeter. If no power there then check the voltage at the ends of each of the battery posts. You have a flat battery is my prediction.
If the battery is delivering power then it will likely be ignition relay, switch, or starter. You can't fix any of those yourself very easily and warranty would apply.
Suberman is offline   Reply With Quote
Old 10-31-2013, 10:54 AM   #8
SmsAlSuwaidi
Boosted
Yeah its completely drained out of power. i thought that if a battery is drained it would still do a bit of work, but i guess ill try and see if its the battery today. If not guess ill tow it to the dealer ship.
Old 10-31-2013, 10:54 AM   #9
SmsAlSuwaidi
Boosted
Yup, it wont even unlock it self, id have to do it manually
Old 10-31-2013, 11:01 AM   #10
Ozzman
Drives: old
To resurrect the car you need to get it towed to the top of the tallest mountain you can find and wait for a nasty thunderstorm. Make sure it get struck by a lightning bolt containing a minimum of One point twenty one gigawatts and you should be good to go.
Ozzman is offline   Reply With Quote
Old 10-31-2013, 11:33 AM   #11
SmsAlSuwaidi
Boosted
So my car's frankenstein now
Old 10-31-2013, 11:37 AM   #12
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Have you tried "popping the clutch" to see if it starts up (assuming it is manual)?
alexand3r is offline   Reply With Quote
Old 10-31-2013, 11:52 AM   #13
SmsAlSuwaidi
Boosted
Car has no power to even unlock it self so it's no the clutch issue
Old 10-31-2013, 11:58 AM   #14
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
If you put the key in the "ON" position, roll it forward, press the clutch, put it in first or second gear, then "pop" the clutch back and press it in quickly it should start with no battery needed. Just make sure your cable are tight on your battery and it should recharge.
Here's a video:
[ame="http://www.youtube.com/watch?v=1pj4GY_7q8w"]How to Push-Start a Car with a Dead Battery - YouTube[/ame]
good lord!
The Walking Dead DIM Off-Topic Lounge [WARNING: NO POLITICS] 286 11-02-2014 11:19 PM
Dead Engine LOZZI Issues | Warranty | Recalls / TSB 17 09-26-2013 11:25 PM
D4S Delete? I'm dead serious. TeamZleep Engine, Exhaust, Transmission 64 08-31-2013 12:00 PM
Dead OEM fog light SpyderDan Cosmetic Modification (Interior/Exterior/Lighting) 8 08-26-2013 02:40 AM
g35 brought from the dead bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-25-2012 11:22 PM
