Old 10-29-2013, 05:14 PM   #1
juliog
juliog's Avatar
Drives: 86
Toyota's killer firmware
Pretty technical, but proof that so many car issues today come from bad software:
http://www.edn.com/design/automotive...s-consequences
juliog is offline   Reply With Quote
Old 10-29-2013, 05:50 PM   #2
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
Stack overflow. Toyota claimed only 41% of the allocated stack space was being used. Barr's investigation showed that 94% was closer to the truth. On top of that, stack-killing, MISRA-C rule-violating recursion was found in the code, and the CPU doesn't incorporate memory protection to guard against stack overflow.
A litany of other faults were found in the code, including buffer overflow, unsafe casting, and race conditions between tasks.
I would have expected better from Toyota.
And as a programmer, I find this embarrasing.
R.S-HawK is offline   Reply With Quote
Old 10-29-2013, 05:57 PM   #3
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Wow!!
Old 10-29-2013, 11:38 PM   #4
phrosty
Reeks of expert testimony using a shotgun approach -- i.e. a bunch of "could-be"s versus a definite "this is what caused the issue".
Don't get me wrong, I have no doubt there are bugs -- programmers are far from perfect and even the best, most careful of practices lead to some bugs happening. Coding is hard
The correlative of this is that understanding someone else's code is hard -- I can look at someone's code and list off a ton of "could-be"s, when they've already taken care of the corner cases in some way that I'd only realize upon a deeper analysis.
The article was clearly not written by a programmer. I'd be curious to see the original technical document. This contains some very WTF wording that doesn't mean anything to a programmer:
Toyota missed some of the calls made via pointer, missed stack usage by library and assembly functions (about 350 in total), and missed RTOS use during task switching.
It lists a number of things which are not bugs, but merely describe a lack of safety nets to catch certain very specific types of bugs:
Toyota claimed the 2005 Camry's main CPU had error detecting and correcting (EDAC) RAM. It didn't.
Mirroring (where key data is written to redundant variables) was not always done.
And some things here which could be bugs but the rest of the article leads me to think they just mean a potential for bugs -- this kind of code has been deemed attention-worthy by the software industry due to being difficult to get right and being the most common areas to find bugs:
phrosty is offline   Reply With Quote
Old 10-29-2013, 11:43 PM   #5
suaveflooder
time for an aftermarket tune!
suaveflooder is offline   Reply With Quote
Old 10-30-2013, 02:20 AM   #6
ft_sjo
Drives: GT86
No. A tune does not touch any of this.
Old 10-30-2013, 03:49 AM   #7
fistpoint
Drives: Supercharged Golf Cart
Sounds like you are describing an inefficient programmer, partially what the article is saying.
fistpoint is offline   Reply With Quote
Old 10-30-2013, 04:05 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-30-2013, 04:25 AM   #9
PantsDants
Drives: Scion FR-S A/T, Whiteout
Exactly. My understanding is that all a tune does is change a bunch of constants (the spreadsheets/data tables of tuning parameters) that the ECU code passes into its functions to Do Things. (Is function the right term here? I come from the land of objects, I dunno about this low-level stuff.)
A tune has nothing to do with said functions nor can it change their implementation.
PantsDants is offline   Reply With Quote
Old 10-30-2013, 05:13 AM   #10
ft_sjo
Drives: GT86
The flash (or multiples of) will contain program areas and data areas. Tuning typically affects the latter, however people like EcuTek bastardise the program area for their 'RaceROM' thing. It can lead to instability issues though, which was exhibited on our cars with the fuel gauge playing up, for example. I believe they pulled that code/hack now.
Old 10-30-2013, 06:25 AM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
For a long time now Toyota has been ruled by Committee not Passion ! They still have an enviable reputation for design & build quality but it has been slipping . . . . unfortunately :/
ZZT86 is offline   Reply With Quote
Old 10-30-2013, 08:05 AM   #12
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
everytime i read "unintended acceleration" on the internet, i always think of this:
http://www.nasa.gov/topics/nasalife/...ota-study.html
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 10-30-2013, 10:17 AM   #13
phrosty
Indeed. In my experience, programmers who don't write straightforward code outnumber the ones who do.
Old 10-30-2013, 12:58 PM   #14
Tromatic
"Firmware" means hardware. You may be able to flash a new version of the firmware, but if the hardware itself is busticated there's not much you can do.
If I were Toyota, I'd be having a lawyer make a phone call about this headline:
Toyota's killer firmware: Bad design and its consequences
Tromatic is offline   Reply With Quote
ecutek firmware problem ahk Software Tuning 5 07-29-2013 10:31 AM
Unichip Firmware issue jybrd Software Tuning 11 07-22-2013 02:40 PM
BRZ Nav Unit Firmware michaelahess Electronics | Audio | NAV | Infotainment 5 05-09-2013 08:55 PM
Veyron Killer: Switzer GTR tranzformer Other Vehicles & General Automotive Discussions 6 03-19-2012 07:43 PM
the BMW killer! RRnold Off-Topic Lounge [WARNING: NO POLITICS] 10 08-28-2010 01:48 AM
