Old 10-29-2013, 01:42 AM   #1
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
TE37V: DIREZZA DZ101 245/40R17 or NT555 235/45ZR17
Hi,
I've picked up a set of TE37V 17x9 rims along with RCE Yellow springs. My problem has come with sourcing tires in UAE.
After calling around different places looking for something relatively cheap but still half decent. (PSS on PassatCCv6 experience) I'll pretty much come down to two different tires based on size, cost and overall internet impressions.
Dunlop DZ101 245/40R17 or Nitto NT555 235/45ZR17, Dunlop's cost 544USD and Nitto's 397USD. My ultimate issue is that I wanted 235/40/17 unfortunately not available anywhere I can find.
Which tire would you go for and why?
Cheers!
Sam
MaXimus is offline   Reply With Quote
Old 10-29-2013, 04:34 AM   #2
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Go for Dunlop DZ101 245/40R17
This is almost like the factory setup Diameter (in %) while the 235/45/17 is about 2.5% off.
Also, 235 will be a bit streched on 9" wheels
Killerbee is offline   Reply With Quote
Old 10-30-2013, 02:16 AM   #3
MaXimus
Meh!
MaXimus's Avatar
180 views and just 1 reply.
Come on guys, please chime in.
Old 10-30-2013, 02:38 AM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I agree with bee, that or a MPSS both would serve excellent.
Old 10-30-2013, 04:38 AM   #5
MaXimus
Meh!
MaXimus's Avatar
One more option to add to the list.
Nitto Invo 225/45R1, please don't suggest other brands or tires since its very hard to get different sizes in the uae.
Thanks!
Old 10-30-2013, 01:32 PM   #6
WhiteLightning
WhiteLightning's Avatar
Drives: 2013 Whiteout FR-S
I see a lot of people running 225/45/17 on 17x9 rims? Here's some links to those pages.
Here's a link: http://www.ft86club.com/forums/showthread.php?t=28437
This thread has some other tire sizes too: http://www.ft86club.com/forums/showthread.php?t=17242
Hope this helps!
WhiteLightning is offline   Reply With Quote
Old 10-30-2013, 01:57 PM   #7
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
I really liked the INVO's for 'swap-ability' left to right, as directionals prevent this.
The INVO's would be the most 'street' type of tire you have listed, as the Direzza and NT555 are more like autocross stickies, iirc. the Invos would last longer for regular use, unless you like the stick and don't mind replacing worn tires in about 12k-17k miles.
Hope it helps, if you like the stretch, then what I said above doesn't really matter due to a limited contact patch.
Eric G
mkiisupra is offline   Reply With Quote
Old 10-30-2013, 01:59 PM   #8
DarkSunrise
DarkSunrise's Avatar
I know someone who autocrosses on DZ101's and he's not overly impressed with them. I'd go with the NT555's since they're cheaper.
2022 BRZ Build
2013 FR-S Build
Old 10-30-2013, 04:34 PM   #9
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Did you happen to do a 5x114.3 hub swap? or are you using adapters?
slicktop is offline   Reply With Quote
Old 10-30-2013, 06:20 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Not a fan of the 555 nitto. Had them on a few previous cars. Ok dry traction, bad wet traction. I buy Michelin tires now. My $.02
Old 10-30-2013, 06:52 PM   #11
PERRIN
PERRIN's Avatar
245/40-17 is the best size in my opinion
PERRIN is offline   Reply With Quote
Old 10-30-2013, 07:06 PM   #12
jeebus
Drives: 2015 Mustang GT (on order)
235/40/17 is just not a common sized tire. You won't find many options there. 245/40/17 is nearly identical in diameter to factory, so just do that.
jeebus is offline   Reply With Quote
Old 10-31-2013, 03:08 AM   #13
MaXimus
Meh!
MaXimus's Avatar
Nope,
5x100 rims. Think they where custom ordered from ravtec?
Old 10-31-2013, 03:24 AM   #14
MaXimus
Meh!
MaXimus's Avatar
Hope this helps!
Thanks a million dude!
I've gone through and it seems I might have issues with rubbing considering most of the guys are running coilovers with 1.##" drop and -2.0 degree camber.
I'm only throwing on the RCE Yellow springs which yield 1" drop and camber bolts which from my research will give you around -1.0 degree of camber.
Anyone can chime in...
dunlop, nitto, te37v, tires
TESTING WATERS: ENKEI KOJIN W/DUNLOP DIREZZA DZ101 18X8.5 F & 18X9.5 R rb123 Canada Classifieds 38 03-30-2014 10:21 AM
SOLD FS: 235/40R17 Goodyear Eagle F1 tires garfull Wheels and Tires 4 08-16-2013 11:35 AM
Mach V's new BRZ on 17x9, 255/40R17 Mach V Dan BRZ Photos, Videos, Wallpapers, Gallery Forum 70 01-03-2013 07:07 AM
NT555 vs Continental DW JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-17-2012 03:18 PM
