Old 10-24-2013, 01:15 PM   #1
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Installed Greddy Intake, kept stock snorkel.
Title pretty much says it all. I installed the Greddy Momentum intake. The instructions said to remove the stock snorkel, but the opening for the intake fit perfectly so I just kept it on. Is there anything wrong with doing so? Did I ruin the purpose of even putting an aftermarket intake on? I still can feel the power boost and torque gain, also gives it a nice engine tone too.
CodyFRS is offline   Reply With Quote
Old 10-24-2013, 01:24 PM   #2
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Sorry man, but...
. Go back to stock
. Install a decent drop-in filter
. Remove or modify your existing snorkel for better airflow or just replace it with an HKS air duct
. Do a sound tube delete while your at it
. Get a tune!
. Sell your Greddy
And in that order! If someone would have gave me these instructions months ago, I would have saved alot of money on intakes
Reason: Stock intake with a drop-in filter & tune is as good or better than any aftermarket intake
If you want to keep your Greddy, just remove and replace with modified snorkel or an HKS - Get a tune if you don't already have one
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following 3 Users Say Thank You to JPxM0Dz For This Useful Post:
CodyFRS (10-24-2013), EvilBeaverFace (10-24-2013), SkAsphalt (12-11-2014)
Old 10-24-2013, 04:47 PM   #3
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Thank you for your reply, I'm going to keep my GReddy, I am getting a tune down the road as well.
Old 10-24-2013, 05:32 PM   #4
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Agree with @JPxM0Dz
If you don't want to modify your snorkel then taking it off is better than keeping it.
EvilBeaverFace is offline   Reply With Quote
The Following User Says Thank You to EvilBeaverFace For This Useful Post:
JPxM0Dz (10-24-2013)
Old 10-24-2013, 08:54 PM   #5
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Don't forget a smoother inlet tube with the drop in, then you are set.
jordanrw260 is offline   Reply With Quote
Old 10-24-2013, 10:14 PM   #6
zooki
Drives: waiting on a 2021...
Keep the stock snorkel. It's not hurting anything. When AEM was designing their intake they flow benched their setup and with the snorkel attached it flowed around 500 CFM, which will support a bit more horsepower than these motors make. It's the only place I've ever seen an intake for one of these cars actually flow benched. It will probably support 250-275 HP if I remember the old rule of thumb from my drag racing days.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Fast_Freddy (12-11-2014)
Old 10-24-2013, 10:46 PM   #7
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
You may want to look into the Perrin 3". Looks pretty promising especially for full bolt ons.
You definitely want to look into a tune though it will wake the car up.
TopGearSolutions is offline   Reply With Quote
Old 10-25-2013, 07:22 AM   #8
EvilBeaverFace
Taken from a software tuning thread
Originally Posted by shiv@vishnu View Post
Originally Posted by ck-GT86 View Post
Just confirming that removing the fresh air snorkel will make a difference, yes?
.ck
Sent from my HTC One using Tapatalk
Correct. From our dyno testing, we saw no appreciable gains with replacing a clean stock filter with a clean new foam filter from Perrin. But repeatable gains when removing the snorkel completely. The advantage of going with a drop in panel is more of a long term thing I think. The aftermarket ones will see less less restriction as they accumulate dirt.
Shiv
Old 10-25-2013, 01:07 PM   #9
zooki
So is everyone else who showed an increase in power with drop in filters on a dyno incorrect? It seems we have conflicting reports on if drop in filters make power. If filters, why not the snorkel?
And what were the repeatable gains? Something like 2-3 HP? Well within the normal variance of measurement, I would think. That's like a 1-2% difference? I mean, you can take it off if you want, it won't hurt anything.
Old 10-25-2013, 02:02 PM   #10
EvilBeaverFace
A gain is a gain, I'm not trying to be nit-picky here but some people will want it and some people won't care. Why not be informed?
I wasn't arguing anything else so I'm not sure what you were getting at with the drop in filters.
Old 10-25-2013, 02:59 PM   #11
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I'm running a K&N drop-in filter, DSport did an extensive test on the intakes compared to drop-in filters. Very similar results, I think short-rams/cold-air intakes are mostly for show and the annoying ricey suction sound for these cars.
Sure, there may be gains for other cars, but very marginal from all the tests. And like how everyone has said, get a tune; I'm running the Vishnu tune with the K&N, sounds great to me and I can feel a difference.
I thought about removing the snorkel completely, but decided not to. Take a look at the point of attachment to the stock box, the engine can evidently intake heat from the engine, often referred to as heat soak. So what I'm going to do is keep the snorkel on, but cut off the fresh-air tube -- many folk have already done this. The idea is to filter out any potential hot air seeping into the intake.
The stock box with a drop-in is more than enough, you can take it a step further and get a replacement intake hose (I just bought a Mishimoto). Wont have to worry about dealership giving me crap for having a new intake/engine mods.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
CodyFRS (11-30-2013), EvilBeaverFace (10-25-2013)
Old 10-25-2013, 03:42 PM   #12
EvilBeaverFace
yeah I've seen a lot more threads springing up where its about someone modding a snorkel like @Yruyur or they've mentioned that they already have or are interested in it.
Yruyur (10-25-2013)
Old 11-30-2013, 03:02 PM   #13
Darkrune
Darkrune's Avatar
Drives: 2017 86
Good info in this thread. It also goes to show that the engineering for this vehicle is pretty sold on the intake side for a full blown intake to not have much effect. Either that, or there is a restriction plate in front of the mani....which makes not sense on a low hp car that has no racing requirement.
Darkrune is offline   Reply With Quote
Old 11-30-2013, 06:34 PM   #14
infinite012
Drives: 13 DGM BRZ Ltd
The intake on the WRX/STI has long been proven to flow more than basic bolt-ons will require. Nobody really changes out the intake unless they want more sound and/or going ginormous turbo.
infinite012 is offline   Reply With Quote
AFe Intake -with or without snorkel? gms Engine, Exhaust, Transmission 2 10-25-2020 04:23 PM
Does anyone have a GReddy Intake Installed? Massdrop Northern California 6 08-01-2013 03:02 AM
Changing Intake Snorkel JDKane527 Engine, Exhaust, Transmission 10 05-07-2013 11:27 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Bigger Intake Snorkel Duct? Anorexic 86 Engine, Exhaust, Transmission 8 01-29-2013 01:00 PM
