Old 10-24-2013, 06:46 AM   #1
Raven23
Which comes first? Opti coat or clear bra
I plan on getting both opti coat and a clear bra for my brz. With that said, which one should come first? I figured opti coat first, but then the coat would be pretty useless in the front end where I plan to get it clear bra'ed. So should I opticoat the clear bra? Would that work or do anything? I read that you could OC a clear bra. Anyone done this? Suggestion?
Raven23 is offline   Reply With Quote
Old 10-24-2013, 08:37 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Bra then opticoat.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 10-24-2013, 02:14 PM   #3
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Originally Posted by slicktop View Post
Bra then opticoat.
I believe this is incorrect. You should Opticoat, then Clearbra.
Opticoat is a second clearcoat that should not be applied to a clearbra.
By opticoating the whole car, you have a completely sealed car for when you decide to remove, replace the clear bra.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 10-24-2013, 02:41 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
when they alcohol wipe the panels down prior to applying the clear bra, you pretty much strip off the opticoat. kinda useless to have it done first.
Old 10-24-2013, 04:28 PM   #5
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
I had opticoat installed and as far as I'm aware of the only way to remove it is by polishing it down. Naturally it will deteriorate and become less effective as the years go on so I will eventually have it reapplied.
Saying the prep for installing a clear bra would dissolve opticoat is like saying that an alcohol rub down would strip the factory clear coat.
Have you had first hand experience with your claim?
φφκα
Old 10-24-2013, 05:28 PM   #6
slicktop
When you opticoat then bra, you have essentially rendered the opticoat worthless. If you do it this way, any imperfections on the bra show up and you're back to square one.
Bra, then opticoat.
Old 10-24-2013, 05:30 PM   #7
slicktop
As far as I know, you have to abrade the opticoat off. I don't think alcohol wipes will take it off.
Old 10-24-2013, 05:39 PM   #8
spitfire481
Drives: 2JZ FRS
People don't understand it's nothing like a clear coat. It is in no way comparable to a legitimate clear coat. It's basically a super thin, longer lasting wax. If an alcohol wash down does not take it off or break it down severely I would be very impressed. My experience is that I do body/paint for a living, and we do Xpel clear bra films as well
But, even if heavy alcohol prep doesn't remove the opticoat, what's the point in having it under clear bra film anyway?
The Following User Says Thank You to spitfire481 For This Useful Post:
Cjymiller (10-24-2013)
Old 10-24-2013, 05:47 PM   #9
Burrcold
Drives: Subaru BRZ Limited
I had opti-coat done first, then decided on a clearbra so the detailer opti-coated again over the clearbra. Made perfect sense to me.
The Following User Says Thank You to Burrcold For This Useful Post:
ExtremeAutowerks (10-24-2013)
Old 10-24-2013, 05:49 PM   #10
ExtremeAutowerks
ExtremeAutowerks's Avatar
Drives: Scion FRS
It is possible to opticoat your whole car, clearbra it, then opticoat the clear bra Doesnt hurt to protect that clearbra as well.
ExtremeAutowerks is offline   Reply With Quote
Old 10-24-2013, 08:08 PM   #11
David-Fermani.com
David-Fermani.com's Avatar
Drives: Dirty
There is nothing wrong with Opti-Coating your PPF. It's actually encouraged because it will provide additional protection to the film.
Ideal situation would be to coat > bra > correct swirls from installer > coat.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit
David-Fermani.com is offline   Reply With Quote
The Following User Says Thank You to David-Fermani.com For This Useful Post:
Old 10-24-2013, 08:24 PM   #12
Raven23
unfortunately, ill be going to 2 different installers for each product. Cant seem to find a reputable installer in san diego that does both. So OC , CB , then OCing again wouldnt be the best move financially.
Old 10-24-2013, 09:46 PM   #13
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
^ This.
Myv is offline   Reply With Quote
Old 01-22-2014, 02:58 AM   #14
KSpider
KSpider's Avatar
Drives: '14 S4
I have 2500 miles on my black BRZ, is opticoat definitely something I should look into?
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Which comes first: Opti-Coat or clear bra? @Art_Mighty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 33 11-06-2016 12:37 AM
Clear Bra and Opti Coat NorCAl kwh3 Southern California 19 11-05-2012 10:35 PM
Opti-coat and Clear Bra benoh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 07-19-2012 08:53 AM
clear-bra or opti coat jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-06-2012 10:21 AM
opti coat + clear bra wallace03 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 06-21-2012 08:09 AM
