Old 10-24-2013, 01:43 AM   #1
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
First Service Appointment: help with my punch list
Tomorrow AM I take my 10 series in for my first service at 5K mi at it's home dealership. I had the oil changed at 1K elsewhere, but I'm not even going to mention that fact tomorrow.
So, obvi I will have the oil changed. My question is what else have twins owners had done or had luck with getting the dealer to do for repair/maintenance?
Here's what I have so far:
-change oil
-rotate tires
-engine makes a squeaking/chirping sound at idle - i know it's the Crickets but i will play dumb for them as I want the crickets documented on my file and vehicle history in Scion/Toyota database.
-shifting gears grinds in 1-2-3-4.
-loose coin or nut rolling around inside drivers door.
What else to ask for at the dealer 1st service?
I plan on being relentless with the Crickets and continue to present my car to the dealer with the Cricket complaint for as long as it continues to happen.
Jertronic is offline   Reply With Quote
Old 10-24-2013, 02:35 AM   #2
iketeru
Drives: Whiteout 6MT FR-S
I'm over 5k and haven't spent a dime at a dealership.. why not change oil/rotate tires yourself? it's part of the fun of ownership IMHO.
iketeru is offline   Reply With Quote
The Following User Says Thank You to iketeru For This Useful Post:
strat61caster (10-28-2013)
Old 10-24-2013, 02:38 AM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i hope you dont come back to this thread and say your dealer filled your car with 7qts of oil.
lots of horror stories has surfaced here in the forums
DIY is the best!
86_ZN6 is offline   Reply With Quote
Old 10-24-2013, 02:42 AM   #4
Jertronic
Jertronic's Avatar
I like free things and this oil change is free. I appreciate the lack of confidence in the dunce techs who do this work at dealer service but I'm thinking I can get tires rotated for free. First thing I do when I leave the dealer will be to check the oil level.
Old 10-24-2013, 03:15 AM   #5
uEih
Drives: CBS Subaru BRZ Limited
I'm going to get my first oil change free soon also so this is helpful. After that it'll be a DIY.. I just want the first one at least to be done by them. I pretty much have the same issues as you do. Also what is this 7 qt of oil horror story about?
uEih is offline   Reply With Quote
Old 10-24-2013, 06:24 AM   #6
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Check your lug nuts too...
Nissan dealer rotated tires on wife's Sentra, forgot to tighten nuts on right front wheel. Results not pretty.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 10-24-2013, 09:53 AM   #7
Fallen43
Drives: Sliver FRS done the way I like it
Are you kidding with this post ?
Fallen43 is offline   Reply With Quote
Old 10-24-2013, 10:06 AM   #8
Brndn704
Brndn704's Avatar
They do rotate the tires for free, unless you have a staggered setup like myself. I believe it's only free for the first three times, after that I would suggest doing it yourself.
Brndn704 is offline   Reply With Quote
Old 10-24-2013, 10:13 AM   #9
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Wash the entire car, detail it inside and out, test drive for faults, remove and rebuild engine and transmission just to ensure there are no defects......
Seriously?
Change the oil and filter but only because Subaru insists, their required change interval is positively antediluvian.
That's it.
Suberman is offline   Reply With Quote
Old 10-24-2013, 10:26 AM   #10
Steve201brz
-Have em put silicone on your window seals
-Top off all fluids
-mark the oil filter so you know they actually changed it
Not many mechanics service cars like it's their own. Laugh if you want but cars are too big of an investment to cut corners on. Theres been too many horror stories. Don't have faith in dealerships until you get to know them
Steve201brz is offline   Reply With Quote
Old 10-24-2013, 10:39 AM   #11
frslee
Just drive it
Drives: 13' FR-S
x2 on marking filter. Scratch the top with your keys and also make mark on wheel, so you know they rotated it (put a bit of tire shine on front wheels)
frslee is offline   Reply With Quote
Old 10-24-2013, 11:19 AM   #12
humfrz
Very good tips.
Also, I'd tell them NOT to wash the car!
(I had a dealership ..... once .... that must have used Comet cleanser .... )
humfrz
Old 10-24-2013, 11:23 AM   #13
AznBRZer
Drives: 16 CBS WRX Limited
Do you have a winter beater? If you don't, I see no need to rotate the wheels if you're going to throw winter tires on them in a few weeks.
AznBRZer is offline   Reply With Quote
Old 10-24-2013, 11:56 AM   #14
dnavas
Drives: Elantra & UM A/T FR-S ex-Saturn
Wow, I could have written this post.
Same problem -- wife's Sentra, nut fell off on road, but was held by hub cap. Made a racket. Fortunately, was able to put it all back on right before worse things happened.
dnavas is offline   Reply With Quote
CEL list? draggin_az Issues | Warranty | Recalls / TSB 2 05-14-2013 03:25 PM
Mod list before car, anyone else? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 13 03-01-2013 08:53 AM
TSB list? DarrenDriven Issues | Warranty | Recalls / TSB 15 11-03-2012 07:38 PM
Detailing Appointment Made! RKC Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-03-2012 02:07 PM
