Old 10-23-2013, 06:35 PM   #1
liajet24
Drives: Argento FRS
How to remove the interior dash trim?
How do I remove the interior dash trim? The bezel around the stereo that extends off to above the glvoe compartment? Does anybody have a video of it being removed? or pictures?
liajet24 is offline   Reply With Quote
Old 10-23-2013, 06:44 PM   #2
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Just place fingers under the plastic above the glove box and apply pressure and pull up and out. It will pop out and then you just move around the edge. It's quite easy. Then once that is done do the same to the radio surround work from the edge facing the glove box and move around the edge firm but slight pressure. It will pop out easy and off.
Rumbaar is offline   Reply With Quote
The Following User Says Thank You to Rumbaar For This Useful Post:
Baldoak (02-18-2016)
Old 11-30-2013, 07:03 AM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Is there a video DIY on this that I just cant find?
Old 11-30-2013, 02:26 PM   #4
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
It's as easy as Rumbaar describes, but if you want video, check out the OEM Audio Plus install guide (jump to about 1:41 in):
[ame]http://youtu.be/LytAyXbgS5w?t=1m41s[/ame]
The passenger side dash panel removes in the same way as the head unit trim does.
rishi is offline   Reply With Quote
Old 11-30-2013, 02:34 PM   #5
BlueDubbinTDI
I guess that helped thanks bro
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 08:47 AM
WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. Tim_Asphalt_FRS Interior Parts (Incl. Lighting) 1 05-13-2013 07:25 PM
Leather wrapped interior pieces (including dash trim) pics Gen Cosmetic Modification (Interior/Exterior/Lighting) 36 11-18-2012 04:08 PM
Possible CF dash trim panels, how to remove stock? jm1681 Cosmetic Modification (Interior/Exterior/Lighting) 1 10-11-2012 02:18 PM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 10:20 AM
