Old 10-18-2013, 01:17 AM   #1
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
All in 1 Day - Plasti Dip Emblem & Wheel + Caliper Paint (First timer)
Finally hit hit triggers on plasti dip stuff, never done it before. but it seems fun and low cost to put on some cosmetic.
Plasti dip the dash board. Red plasti dip, apply 4-5 coats on it and only used little over half can. Then use Glossifier to finish up with 2 coats.
Plasti dip the back seat 2 piece caps. Same, use red plasti dip apply 3-4 coats then finish with 2 coats of Glossifier.
Plasti dip the stock wheel. I used Vintage Gold, apply 6-7 coats and used 4 cans total for 4 wheels. Finish with the Glossifer about 3-4 coats at the end. The note cards are very helpful.
Plasti Dip the emblem with Vintage Gold as well. I also put on Glossifier on the emblem as well, looks little shinny under sunshine.
Caliper Paint on stock break caliper
Final Turn out
Old 10-18-2013, 01:35 AM   #2
MotorboatinSonOfA
MotorboatinSonOfA's Avatar
Drives: 2013 Scion FR-S - Raven MT
Wow, I didn't think this much could be done in one day. Did you do anything to prepare for the plasti-dip on the wheels? I heard you have to clean the wheels and then afterwards apply some kind of special spray before the plasti-dip. Then after the pasti-dip you have to spray a few different things on.
MotorboatinSonOfA is offline   Reply With Quote
Old 10-18-2013, 01:59 AM   #3
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I am first timer, before I thought plasti dip was complicate but it was totally much easier and simpler then it was.
I clean up the wheel with water and soap, let it be total dry. apply the first coat of plasti dip, have to be very light on the first coat. wait 10-15 minute then apply the second coat. wait 10-15 min then apply 3rd coat, and same as the 4th coat.
After the plasti dip get dried, I just put 2-3 coats of Glossifier on the wheel.
I use the wait time between the plasting to clean my caliper break with the de-grease break cleaner that you can get from autozone or walmart.
I use VHT red caliper paint, it works flawlessly. I had the car to be sit in the garage over night to let the caliper paint be total dry before use.
Old 10-18-2013, 03:53 AM   #4
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
looking great!
I've been pondering about doing the classic gold on my wheels on WRB BRZ
Where did you get your dip from?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 10-18-2013, 05:34 AM   #5
Muskokan
Drives: white Sport-tech
How do you go about plasti dipping around the lug holes? What does it look like close up?
Muskokan is offline   Reply With Quote
Old 10-18-2013, 10:38 AM   #6
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I got my D1 Spec Lug Nut from EBay. They are blue color.
Sent from my iPhone using Tapatalk - now Free
Old 10-18-2013, 10:39 AM   #7
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by wrb View Post
looking great!
https://www.dipyourcar.com/
Old 10-18-2013, 12:30 PM   #8
z3ro
diggin the wheels.
might steal that part of your project..........
how many cans to do all 4 wheels?
z3ro is offline   Reply With Quote
Old 10-18-2013, 12:36 PM   #9
vividracing
vividracing's Avatar
Looks good. The wheels turned out great and looks professional. That little girl was a Pro.
vividracing is offline   Reply With Quote
Old 10-18-2013, 01:16 PM   #10
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by z3ro View Post
diggin the wheels.
4 can totally works for 4 wheel. I bought 6 cans total just in case is not enough. plus 2 cans of Glossifier for the touch up the wheels at the end.
@vividracing , yea that little girl was a little PRO. thanks
Old 10-18-2013, 01:51 PM   #11
vividracing
You thinking about lowering it?
Old 10-18-2013, 02:09 PM   #12
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I do. I am waiting for the TRD lowering spring which assume that will be out by November. I am saving $$ for it at this point.
Old 10-18-2013, 03:42 PM   #13
vividracing
I'll keep an eye out for you. Hit me up when you are ready. I'll get you a good deal.
Jacky
Old 10-18-2013, 09:53 PM   #14
cslntuee
Drives: Subaru BRZ Limited
It looks great.
Where did you buy the driving wheel cover?
Thanks.
cslntuee is offline   Reply With Quote
Brake caliper paint WRB-DZA-BRZ Cosmetic Modification (Interior/Exterior/Lighting) 45 10-05-2016 01:02 PM
DIY - Caliper removal and paint olorin DIY (Do-It-Yourself) Guides 9 04-04-2014 10:12 AM
vinyl wrap or plasti dip fr-s emblem? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 13 12-17-2012 09:01 PM
Caliper Paint w/emblem Customization Kimsey47 Cosmetic Modification (Interior/Exterior/Lighting) 24 10-06-2012 02:08 PM
RED G2 BRAKE CALIPER PAINT?? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-03-2012 01:38 AM
