Old 10-17-2013, 07:38 PM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Installed New GReddy Differential Cover!
New GReddy Differential Cover Scion FR-S / BRZ
We @Evasive Motorsports just finished installing the new GReddy precision cast aluminum Differential Covers prolong the life of your limited-slip differential, by increasing oil capacity and cooling. Internal baffles control oil slosh, while an integrated 3/8PT port can be used for external cooler for extreme usage. We will be testing at the track for Super Lap Battle in a few weeks coming up. We also finished installing a new Carbonetics LSD as well. The Carbonetic Carbon LSD provides stable and linear traction during acceleration and deceleration regardless of the road conditions or driving style. Constructed using the durable clutch style design, this ensure that the clutch engages exactly how you want it. Featuring a 1.5 way engagement, the ramp angles are designed specifically to suite the particular application. Compared to metal based clutches, carbon offers smooth linear engagement for more predictable control. The Carbon LSD is suitable for the street, track, drifting and even rallies. Finally added Motul Gear 300 which plays a big important role making the LSD more efficient with more consistent and better reliability in the LSD!
- More than twice the differential lock strength of metal LSDs
- High carbon friction material increases the coefficient of friction
- Low initial drag resistance with reliable performance (surpasses more than 5 times that of metal LSDs)
Recommended Fluids:
Motul Gear Competition FF Gearbox & LSD Oil - 75W140 (for competition use)
Motul Limited Slip Differential Fluid 90PA (for daily driving)
(Extra ports for oil cooler)
Evasive Motorsports is offline   Reply With Quote
Old 09-14-2015, 07:13 PM   #2
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
It looks like it hangs dangerously low, or an I crazy?
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Mach V Motorsports differential cover Mach V Dan Engine, Exhaust, Transmission 35 12-06-2014 04:52 PM
Installed New GReddy Differential Cover Evasive Motorsports Engine, Exhaust, Transmission 1 10-17-2013 07:17 PM
NEW Greddy FR-S BRZ High Capacity Differential Cover w/ FREE SHIPPING -GET YOURS NOW! 468Power Transmission and Driveline 4 10-06-2013 08:05 PM
NPA: Greddy FR-S / BRZ High Capacity Differential Cover 86_Insider Engine, Exhaust, Transmission 9 09-27-2013 11:41 PM
Get your Cusco Differential Cover from Kronos! KronosPerformance Transmission and Driveline 5 07-04-2012 09:33 PM
