Old 10-15-2013, 12:37 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
Vortech and cusco oil catch help
Hey everybody. I'm wanting to put in a oil catch can but unsure of how to route it in terms of plumbing w the vortech. Any help would be great! Thanks !!!
ft86me is offline   Reply With Quote
Old 10-15-2013, 12:45 PM   #2
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Where does the PCV Hose mount on the Vortech Kit?
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 10-15-2013, 12:53 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
Thanks for the reply ! I believe the one vortech had me splice in one is from the top of the intake manifold and goes down to the block.
Old 10-15-2013, 12:55 PM   #4
Team STILLEN
Mark @ STILLEN
If you spliced one that goes to the intake manifold from the PCV (Positive Crankcase Ventilation) which would be on the Valve cover(s)...that is where you would mount the catch can between. I would look over the instruction and see if that is the PCV line.
Where did you splice it to?
Old 10-15-2013, 01:02 PM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
I know this is no help but I honestly don't remember. It was specific in the instructions and i went to the hose and spliced it there. My car isn't here right now but I'll check once I have it back in a few hours or so
Old 10-15-2013, 01:22 PM   #6
Dezoris
Dezoris's Avatar
I just messaged you. Image is for PCV. (Must use hoseclamps, PCV is under vacuum leaks can cause tuning issues)
For breather run tube behind AC compressor to inlet of second catch can, then outlet of catch can to inlet of Vortech Airbox.
The Following User Says Thank You to Dezoris For This Useful Post:
ft86me (10-15-2013)
need an oil catch can for vortech\innovate superchargers? Benn0r Forced Induction 8 01-17-2014 01:50 AM
Catch can/oil separators on FI engines? (Vortech in particular) BenArmstrong Forced Induction 21 09-19-2013 05:30 PM
F/S Cusco oil catch can wbradley Canada Classifieds 3 07-18-2013 01:16 PM
FS: Cusco Oil Catch Can JPxM0Dz Canada Classifieds 8 04-21-2013 11:46 AM
CUSCO OIL CATCH CAN DIY Margovincent_22x DIY (Do-It-Yourself) Guides 4 01-19-2013 08:18 PM
