Old 10-14-2013, 04:07 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
ST vs KW var3 coilovers
for those who have some sort of experience/knowledge of both...
would you say these are night and day for spirited daily driving? I had the ST coilovers on my wrx and really quite liked them, but noticed my friend's KW ride MUCH MUCH better...(maybe external reservior or just better dampening?) anyways, looks like the spring rates are the same on these so maybe it`s just a matter of quality? the only complaint I had on the wrx ST was that it was progressive springs so it felt a bit soft on the initial bounce and kind of gave me a bobblehead effect.. I was thinking of upgrading to swift springs to get rid of that issue, but i traded in the car for the BRZ before I went ahead onto that route... I`ve been in friends cars with the V3s and they are definitely what i would call smooth... even better than stock IMO. but is it worth all that more compared to the STs?
I also have a friend that works for Bilstein so I could probably get a good discount as well but I have zero experience with Bilstein...
mokinbird87 is offline   Reply With Quote
Old 10-14-2013, 04:08 PM   #2
mokinbird87
BOXER FR
goal of the car is a decently comfortable daily driver that will see 2-3 auto-x a year and maybe 1-2 track days a year.
Old 10-14-2013, 04:33 PM   #3
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
The ST's are essentially the KW V1's with a Galvanized steel out body instead of the SS KW body.
The valving, springs, and internals are the same.
The ST's and the V1's have preset damping. The V3's have adjustable damping for both rebound and compression, so you can "fine tune" the V3's for your needs.
So if you want a nice upgrade and don't care about adjusting the damping yourself go ST. If you want to set the damping then you'll want the V3's. Either kit would be a good buy
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
mokinbird87 (10-14-2013)
Old 10-14-2013, 04:46 PM   #4
mokinbird87
BOXER FR
i think this time around i may shell out a bit more and try and fine tune the dampening myself... i thought the STs were great but I was still wanting more...
Old 10-14-2013, 04:51 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
KW V3 are good street coilovers with the ability to adjust compression and rebound independently which can make the ride "smoother" simply based on being able to adjust those particular parameters a little more freely. ST is basically a KW V1. For the V3, you will need to reuse your stock top hats or purchase aftermarket camber plates. We dial our clients' suspension setups based on their driving preferences. If you are local to the area, we can help you dial them in for you.
CounterSpace Garage is offline   Reply With Quote
Old 10-14-2013, 07:48 PM   #6
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
ST if you want a coilover to go lower than springs. Honestly if you use your car for the street you'll probably never touch any of the adjustments. So it would save yourself a lot of money for options you don't need.
h4nh is offline   Reply With Quote
Old 10-14-2013, 08:04 PM   #7
Circuit Motorsports
The V3's are a very nice kit and I think you'd be happy with those
If you want some help feel free to message us!
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 12:01 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
