Old 10-14-2013, 09:19 AM   #1
Admired
Drives: 2013 Scion FRS
What is the OEM midpipe diameter?
I am going to get fabricated a 14" Magnaflow muffler on the OEM midpipe in hopes to reduce the rasp I am getting from my catless straight pipe setup. Do you think this will work?
Admired is offline   Reply With Quote
Old 10-14-2013, 09:25 AM   #2
FR-S Matt
Diameter I believe is 2.1" give or take a tiny bit last time I measured around. It's small.
Old 10-14-2013, 09:27 AM   #3
Admired
Damn, so what size inlet/outlet should I get for the muffler? 2.25"?
Old 10-14-2013, 09:30 AM   #4
FR-S Matt
That should work. A muffler shop should be able to weld it on that size and most of those mufflers have inlets that size as well.
Old 10-14-2013, 09:35 AM   #5
Admired
You think 14" or 18" length? Want reduction in rasp but not sound.
Old 10-14-2013, 09:52 AM   #6
FR-S Matt
Hmm, that's a tricky one. 18" if you for SURE want it to reduce the rasp. 14" might be questionable. It's really hard to say until you actually hear it. I've got two 14" resonators in my exhaust and its still loud, but it took out any chance of rasp.
TRD Exhaust Pipe Diameter Jacob G. Engine, Exhaust, Transmission 24 04-10-2018 08:18 PM
Diameter of OEM crank pulley? ft_sjo Engine, Exhaust, Transmission 0 02-22-2013 04:17 PM
Front Spring Diameter Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-17-2012 12:06 PM
FRS exhaust tip diameter? empower-auto Engine, Exhaust, Transmission 8 07-12-2012 10:36 PM
Exhaust tip fra diameter tintumz22 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-04-2012 04:31 AM
