Old 10-12-2013, 01:20 AM   #1
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Differential Strength Component
So maybe I'm not using the right terminology but I'm just looking for clarification.
Our rear end is a weak point. I'm trying to decide on the best route for upgrades. Looking at 800whp+. The routes currently are the FullBlown 8.8 Ford rear end conversion or upgraded axles/gears in the diff.
My question is, the axles and gearset are the strength of the rear end, correct? The differential casing is just a protective housing... mostly. Is that an accurate statement?
slicktop is offline   Reply With Quote
Old 10-12-2013, 09:38 AM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Not at the power levels you're describing.
All that torque is transferred to the wheels by reaction against the diff housing. One significant advantage to IRS is being able to bolt that diff firmly to the chassis. Live axles bend and twist and jump around under all that torque.
One of the biggest issues with carbon fibre transmission cases developed for F1 was engineering the structure so it would not twist and pop the bearings.
The diff case is a very specialized casting designed to hold all the bearings and seals precisely aligned while that torque is directed at 90 degrees.
Suberman is offline   Reply With Quote
Old 10-12-2013, 09:47 AM   #3
JerryMichaels7
Drives: Whiteout FRS
I have yet to hear of a diff actually going pop...axles yes diff no. upgrade the axles and be done...only plus to going with the 8.8 is ALOT of gear ratios are out there already.
JerryMichaels7 is offline   Reply With Quote
Old 10-12-2013, 10:41 AM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why the hell do you need 800+whp?
Old 10-12-2013, 11:53 AM   #5
Dipstik-sportech
Dipstik-sportech's Avatar
Because racecar. Duh
Old 10-12-2013, 03:55 PM   #6
slicktop
I need 800whp so I can autox around the track faster.
Old 10-12-2013, 03:57 PM   #7
slicktop
Makes perfect sense. Thank you for the reply!
Old 10-12-2013, 04:10 PM   #8
mike the snake
I'm curious about the Ford 8.8 rear end. Is it an independent setup, or straight axle?
Old 10-13-2013, 06:50 AM   #9
slicktop
Independent. Cost is around 5k.
http://www.ft86club.com/forums/showthread.php?t=31474
The strength of an 86... Vic_RSA AFRICA 34 05-31-2016 03:59 AM
Transmission Strength Comparison Wes B. Engine, Exhaust, Transmission 49 05-13-2016 10:54 AM
Component question Gen Electronics | Audio | NAV | Infotainment 1 11-07-2012 12:55 PM
FR-S A/T strength/durability? 07stealth350z Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2012 12:58 PM
