Northern California NorCal
Old 10-11-2013, 01:17 PM   #1
rourich
Drives: Subaru BRZ Limited
Brz just broke 1k miles, clutch begins to feel grindy
So I just broke 1k miles in my BRZ. I have not driven it hard yet and followed the proper break in procedure. But today while I was driving, I noticed something really strange. When I depress on the clutch and release it after changing the gears as I'm releasing the clutch, I can sort of feel like it is grinding against something. What seems to be the problem?
rourich is offline   Reply With Quote
Old 10-11-2013, 01:40 PM   #2
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
Check the clutch fluid.
See if's transparent or dirty. It should be yellowish clear and transparent.
I would start with that.
If the problem persist I would bring it to the dealers attention.
TopGearSolutions is offline   Reply With Quote
Old 10-11-2013, 01:46 PM   #3
MyRx
MyRx's Avatar
^^ nothing. Everything is falling into place and the mechanical parts are getting comfortable with each other. Continue driving it as you please. There are slight remedies to improve that system but if you do it now, you're just throwing $$ away.
There are multi-threads about your experiences but bottomline, you're in the honeymoon phase, enjoy it and drive.
Old 10-11-2013, 01:56 PM   #4
rourich
Great! I'll take a look at that.
Old 10-11-2013, 01:57 PM   #5
rourich
But the grind/scraping of the clutch appeared after reaching 1000 miles. Is this normal?
Old 10-11-2013, 02:08 PM   #6
whaap
whaap's Avatar
Assuming it's the same assembly as in my FR-S, no, it's not normal. I've got 13,000 miles and have never experienced that.
whaap is offline   Reply With Quote
Old 10-11-2013, 02:20 PM   #7
Muskokan
Drives: white Sport-tech
People have experienced grinding/notchy gears, but never heard of the actual clutch feeling like that. Take it in, they'll atleast check your fluid for you and save yourself from getting dirty.
Muskokan is offline   Reply With Quote
Old 10-11-2013, 02:22 PM   #8
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
Someone else complained about the similar occurrences. Then they drove someone else's car and it had the same effect. So it was normal for these cars. So if it makes you feel better. Bring it to the dealer and have them tell you that the car is driving normal. No need to spend money if your car is still under warranty.
RC51ed is offline   Reply With Quote
Old 10-11-2013, 02:30 PM   #9
Boom
(Jo_o)J
Boom's Avatar
Drives: 2013 Raven FR-S
I had that same exact experience with my FR-S. I'm at 1800 miles now, and it's completely gone. Just keep driving it normally, not too hard, and the grinding WILL go away. Dont worry... about a thang.
I like the tuna here
Boom is offline   Reply With Quote
Old 10-11-2013, 03:10 PM   #10
MyRx
MyRx's Avatar
You've been babying pre-1K. Now it's finally being utilized. 2 part shaft, diff, and tranny makes for a lot of moving parts. Not to mention an active suspension to throw in the equation and sub-standard pieces to make all that work in harmony. No, this entire car is not normal. It's fun, sexy, and enjoys to talks back haha
Like mentioned, check the fluid. Check the operation of the clutch from the engine bay. Feel the shifting with load vs idle. Drive another 86 and compare. There's funner things to do than to sit at the dealer. Unless of course you deem it necessary and only you can justify that. Some cars came really smooth and some not so smooth but according to the dealer, "it's normal".
Dublin Toyota meet tonight 730p. Check it out and ask.
Old 10-11-2013, 03:51 PM   #11
rourich
Yeah this makes sense! I'll check the clutch fluid. I'm not sure if I can make the meet but I'll try to drive another 86 to compare.
Old 10-11-2013, 03:54 PM   #12
rourich
Attachment 53913
Sounds like a good idea. I'll drive it for another week after break in to see what happens! And maybe I'll get a chance to drive another 86 to compare.
Thanks!
Old 10-11-2013, 03:55 PM   #13
rourich
Its really subtle. I'll have it checked or something.
Old 10-11-2013, 04:13 PM   #14
rourich
I'm trying to find the post but I can't find it. Do you happen to remember which category the thread was under? Thanks!
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 04:17 PM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
