Old 10-10-2013, 11:37 PM   #1
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
4th gear RPM drop (AT)
Its been doing this for as far back as I can remember. Every time the car shifts into 4th gear, in either M or D after about 1 second in the gear at constant peddle pressure the RPMs will drop about 15% of the rev range from wherever you are for about a half second then go back to where it was before the drop and keep climbing like it should have. It is incredibly noticable in the higher rev ranges obviously as it can drop like 500rpm or more. Driving fairly normal (shifts in the low to mid 2000s) its less noticeable when its like a 100rpm drop. Its always there though no avoiding it. Does anyone have any idea what could be causing this so I can go to the dealer with a little more knowledge. thanks
Old 10-10-2013, 11:42 PM   #2
Craig
Craig's Avatar
Drives: Asphalt FRS
Happens to me too, from what I was told its merely the TQ converter locking in, I've gotten used to it and even utilize it when accelerating. If you add a bit of pressure around the time it usually happens you can lock it quicker, so fast its barely noticeable.
Craig is offline   Reply With Quote
Old 10-10-2013, 11:59 PM   #3
BlueDubbinTDI
Is there nothing that can be done about it? And why would it only be in that gear?
Old 10-11-2013, 01:52 AM   #4
Pandle
Drives: CBS BRZ
Mine does this in second gear. It can be annoying at times...
All kinds of gains....
Pandle is offline   Reply With Quote
Old 10-11-2013, 06:44 PM   #5
Craig
Craig's Avatar
Drives: Asphalt FRS
Happens in all gears, its just more noticeable in 4th. Why does it happen? Its the torque converter locking in.... If you're unfamiliar with how this works this post is very helpful: http://xtremecarzone.com.au/index.php?showtopic=939
You can also check the 'how stuff works' it's really dumbed down but its pretty helpful if you're unaware.
Old 10-12-2013, 11:25 PM   #6
Cadenz
Drives: Subaru BRZ SWP Limited 2013
This happens to me most notably in a 2nd to 3rd shift, and usually only if I'm in M mode.
Cadenz is offline   Reply With Quote
Old 10-13-2013, 10:20 AM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
No chance this is just a lousy execution of rev matching?
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 05:45 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
AT Driver's - 2 Gear Drop Guaruja Scion FR-S / Toyota 86 GT86 General Forum 8 07-29-2012 08:31 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
