Old 10-10-2013, 07:31 AM   #1
Pvt AJ
Pvt AJ's Avatar
Drives: Toyota 86 GTS
PVT AJ Australia - Daily/Light Tracker
I figured I should start a journal of my car since seeing a lot of inspiring builds from other members and I hope it inspires others.
日本語コメントは歓迎されている。
Background: This is my first car journal and open to info and help. I have had my 86 since February 2013. I track it about 6 times a year and occasional drift night/ motorkahana. I am looking to get into some hillclimb events if I have time.
Mod list:
Exterior:
  • TRD antenna.
  • Stock tail lights with TRD winker bulbs.
  • TRD SF2 wheels (Advan Ad08r 225/40/18)
  • Stock front blinker withTRD winker bulb.
  • Stock side blinker with Chrome side marker bulbs.
Interior:
  • TRD shift knob.
  • Cusco sports pedal.
Suspension:
  • Racecomp Engineering tarmac II clubsport.
  • Vorshlag caster/ camber plates.
  • Whiteline rear control arm upper inner bushing (camber correction).
  • Whiteline front camber bolts.
Brakes:
  • Ferodo DS2500 front + rear pads.
  • Project mu Teflon brake lines with stainless joints.
Drive terrain:
  • TRD 2-way mechanical LSD
    Whats Comming Next:
  • Project mu 4-piston 4-pad front caliper kit.
  • Silkblaze front bumper with LED option.
Current Photo:
Pvt AJ is offline   Reply With Quote
Old 10-10-2013, 09:19 AM   #2
ziptiedae86
ziptiedae86's Avatar
Drives: AE86 & Up-Armored ZC6
Looking good so far, you're the first person I've seen on here with the Buddy Club tails installed, they look great in the videos, thanks for sharing!
ziptiedae86 is offline   Reply With Quote
Old 10-10-2013, 09:25 AM   #3
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
ziptie - check mine out
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 10-11-2013, 03:33 AM   #4
Pvt AJ
Pvt AJ's Avatar
Just a couple photos of the buddy club lights for those who don't have instagram.
https://www.dropbox.com/sh/hax6ksekybmsfu7/aMbh-WRlEH
Old 10-12-2013, 06:43 AM   #5
Pvt AJ
Pvt AJ's Avatar
Photo from earlier this year when i cruised to the hunter valley. This would have to be my favorite photo of my stock car.
Old 10-13-2013, 02:29 PM   #6
kALMIGHTY
Drives: TRD Ultramarine '13
Any videos of the buddy clubs with the cascade turn signal effect of the tail lights turned off?
Old 10-14-2013, 04:07 AM   #7
Pvt AJ
Pvt AJ's Avatar
Sorry no I dont have one. If I get time in the next couple of days Ill get one up for you.
Old 11-02-2013, 07:09 PM   #8
Pvt AJ
Pvt AJ's Avatar
A small update on progress so far:
I'm in the middle of installing the RCE Tarmac 2, fronts are in and running brilliant. Just waiting on the rears to go in which hopefully will be in the next few weeks.
I will be throwing in the TRD shift knob today. It looks and feels like really good quality, I will try update on the feel once its on the car.
I picked up a speedhuners tow hook strap (yes I know it is not suitable for direct mounting). A friend of mine in the NSW 86/BRZ club will be making up an eye bolt for me. Then I will remove the stitching and restitch it onto the eyebolt keeping the same stitch pattern. Its purely just for looks on meet days and in the future I might test it's properties to see if it is functional.
Also a video of the lights with the flicker turned off has been uploaded to my dropbox. A night version will be uploaded tonight after it gets dark outside.
Photos and videos are all updated in my dropbox folder
Old 06-22-2014, 08:24 PM   #9
Pvt AJ
Pvt AJ's Avatar
An update on the RCE suspension and other items:
Suspension: they have been in the car for about 6months now and feel great for both daily and track. For daily driving it is not too harsh with the rebound and bump set (I usually run mine at 8 bump and 8 rebound for street). For on the track the setup feels very good, the car stays grounded. I have zero complaints with it at all.
TRD shift knob: not really any difference to the stock shift knob, I thought the stitching might be uncomfortabe but it is fine.
Ferodo pads: they performed great on track and on the road. On road I get slight noise on cold days when the brakes are cold. For the track they withstand good punishment. Some review on properties (1= bad, 10=perfect): initial bite=6, fade=6, life=8.
If there is anything else feel free to ask.
Old 06-22-2014, 08:55 PM   #10
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
The shorter final drive is a great upgrade if you don't plan on putting down gobs of power. I'm pushing somewhere between 250 to 300whp (will know exactly how much on Tuesday) with my 4.56 final drive and I feel it would be too short with any more power. Right now as it sits I have IMO a really well rounded daily driver. Enough power to put a smile on my face with the acceleration from the gearing to get there quicker. My speed limiter is set at 140mph and I hit that in 6th gear at 6800 rpms. I have the power to run through those extra 600 rpms, but since I daily this car, I never come close to seeing those speeds. If you plan on staying all motor, the 4.8 might be a good gearing for you as well. The 4.56 is decent without too much power but a 4.8 might be that much better. I highly recommend a clutch type LSD. I love mine. Makes everything smoother when going through the corners.
Dustin is offline   Reply With Quote
Old 06-23-2014, 04:01 AM   #11
Pvt AJ
Pvt AJ's Avatar
Thanks for your recommendations. With the clutch type LSD did you go with a 1.5way or 2way?
Old 06-23-2014, 09:39 AM   #12
Dustin
Twin Screw You
Dustin's Avatar
2 way
Who dog's there car out on a daily? drift94 Scion FR-S / Toyota 86 GT86 General Forum 23 06-03-2013 10:40 PM
Mileage Tracker App for Android? FRyeS Scion FR-S / Toyota 86 GT86 General Forum 24 05-17-2013 04:03 PM
Daily Use Or Weekender JLMtm Scion FR-S / Toyota 86 GT86 General Forum 64 11-01-2012 12:29 PM
FR-S Inventory Tracker is Up Subie Scion FR-S / Toyota 86 GT86 General Forum 35 09-10-2012 10:29 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
