Drives: ultra marine frs
perrin alittle off center exhaust
I cant find where the thread is but does anyone else have the issue of tips not lining up..
The directions tell you to loosen up the vband clamps and turn the middle pipe until they line up. Mine looks fine.
#3 | |
Run, Reach, Fly
Drives: Monogram Firestorm
Sent from my DROID BIONIC using Tapatalk 2 |
Drives: Scion FR-S
+1 for the clamps mine didnt align either but got em damn close by trial and error with the clamps and pipe.
Drives: 2018 BMW M240i
mine is a little off as well. did not notice until it had been on for a few weeks. too lazy to fix kt
Drives: 86
have someone to hold the muffler while tightening the v clamps make it much easier.
Drives: 2013 FRS Asphalt
I have bad the same issue. Have not tried fixing it yet. Seems fine until the very last clamp then it goes off a little on the right.
2013 Scion FR-S AT Picked up 5/30/2012
Twist the last piece of pipe either up or down to keep the muffler properly aligned.
You need two people and some patience, but you can get it right.
Just a though but doesn't having to twist the pipes and then tighten up, vs just tightening up the way it naturally hangs, create extra stress on the whole system?
It seems like it would create stress on the welds, hangers, and joints since you are twisting the pipe by force and then tightening everything up. |
#10 |
Drives: 2JZ FRS
the mounts are rubber, stress is not really a problem
#11 |
There's enough friction that it doesn't just "naturally hang." It hangs wherever you put it.
Think about it in reverse. Perrin built the prototype exhaust, probably out of a single piece, with everything properly aligned. They then cut it up in a couple places to make it easier to ship/install/whatever and added v-band flanges. Then they built jigs and started producting them. If they had used bolted flanges (which are more prone to leak and need gaskets, etc), it would line up every time. Because they chose (arguably) better v-band, you can (and probably will) install it so it's not lined up exactly the way it was designed. But when it IS lined up correctly, it's exactly like the prototype.
#12 |
Drives: 92 lexus sc300 > whiteout MT FRS
Just got mine, hope its not a hard fix.
#13 | |
#14 |
Hey guys, when aligning the tips on the PERRIN exhausts, you will want to loosten the two V band clamps on the S pipe, adjust the S pipe, then retighten the V bands. You'll want to start with the V band closer to the front of the car first, then do the one one the muffler. The collar clamps that go on the exhaust hangers included in the exhaust will also affect how the exhaust hangs too, so they may need to be adjusted to help with this.
| My idea for a center arm rest / console cover / center cup holder | ravenblackfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 67 | 02-13-2016 03:00 PM |
| Center Exit Exhaust Possible? | sw20kosh | Engine, Exhaust, Transmission | 47 | 01-06-2014 01:09 PM |
| FS: Perrin 4' Exhaust Tips | Mrazn | Exterior Parts (Aero, Lighting, Etc.) | 8 | 09-09-2013 01:31 PM |
| Perrin Catback Exhaust vs Nameless Performance Exhaust. | vignesh | Engine, Exhaust, Transmission | 201 | 06-05-2013 09:47 PM |
| TRD vs Perrin exhaust question | so26 | Engine, Exhaust, Transmission | 0 | 10-19-2012 12:18 AM |
