Old 10-09-2013, 12:15 PM   #1
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Removing the 4000rpm flat spot
SO WHAT DO YOU GUYS THINK?
im probably going to get this in the future. But i wanted to know what you guys thought?
"BRZ & GT86 OBD Tuning Now available in Bahrain, Put some safe Fun life into your BRZ / GT86 15bhp 20Nm Torque gains plus remove the 4000 rpm flat spot, Files written and backed up by one of the biggest OEM Tuning company's in the world." (KAR PERFORMANCE BAHRAIN) it costs 350 BD so about 930$ (with dyno testing)
AZOOZ_95 is offline   Reply With Quote
Old 10-09-2013, 12:19 PM   #2
strat61caster
strat61caster's Avatar
http://www.ft86club.com/forums/forumdisplay.php?f=88
ineedyourdiddly
Old 10-09-2013, 12:25 PM   #3
frslee
Just drive it
Drives: 13' FR-S
Header + Tune
frslee is offline   Reply With Quote
Old 10-09-2013, 01:13 PM   #4
MAPerformance
Drives: Asphalt FRS
Originally Posted by frslee View Post
Header + Tune
^^This. Header and tune on my car now pulls pretty hard from 3200-4k.
MAPerformance is offline   Reply With Quote
Old 10-09-2013, 08:07 PM   #5
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
I fixed mine very nicely... Turbo
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 10-12-2013, 01:13 PM   #6
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Was this a UEL or EL header? @MAPerformance
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 10-14-2013, 10:07 AM   #7
MAPerformance
Drives: Asphalt FRS
Mine is an UEL. But a well designed EL such as the HKS or P&L and soon to be Nameless have show great gains in the dip as well.
Old 10-14-2013, 03:08 PM   #8
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
The Torque dip can actually be significantly improved and almost eliminated with a solid tune, a header is not necessary. We had really impressive gains on a stock car.
Although a Header would make a big difference as well.
-Tristan
Circuit Motorsports is offline   Reply With Quote
Old 10-14-2013, 04:34 PM   #9
sw20kosh
Drives: 2013 Black FR-S
-Tristan
I'd like to see the dyno graph if you have one.
Old 10-14-2013, 06:28 PM   #10
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
-Tristan
PROOFFFF!
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-14-2013, 07:32 PM   #11
Circuit Motorsports
Originally Posted by DriftEightSix View Post
PROOFFFF!
Thread: http://www.ft86club.com/forums/showthread.php?t=47586
Old 10-14-2013, 07:56 PM   #12
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Muffler delete.. is that fair?
mike_ekim1024 is offline   Reply With Quote
Old 10-14-2013, 08:09 PM   #13
DriftEightSix
Pegasus White
Drives: 86
you can't have a basically stock 86! you either have stock 86 or modified 86... that would be a modified 86... with an exhaust modification.
Old 10-14-2013, 10:12 PM   #14
Circuit Motorsports
If you read the thread you'll see that we tested the drop-in filter back to back with the stock filter, they were +/- 1 hp for each run, as in we did a run with the K&N filter at 193, then a second run at 192, change to stock filter and we got a 193 then a 192, same numbers. So that basically shows the filter did nothing for the HP gain or loss.
We also did the same test with the muffler delete, a 1 hp difference either way is so small that usually is down to a variance between dyno runs.
We were very thorough, we didn't want to make claims we couldn't back up. We could get the same results form a bone stock car. We just didn't call it a "bone-stock car" because we knew someone would say - "Hay what about that muffler delete"!
We would be happy to tune someone's bone-stock car to prove it - or to tune anyone elses car so they can see the improvements firsthand
-Tristan
Blind spot? euroshowoff Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2013 04:38 PM
Can you spot the BRZ or GT86? hanabie BRZ First-Gen (2012+) — General Topics 11 08-23-2013 07:08 PM
JDL EUL Header GB Spot JackSmiley Engine, Exhaust, Bolt-Ons 5 08-04-2013 10:05 PM
Help Removing a spot on the wheel tbwoodlee Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 12-31-2012 06:50 AM
Will not rev over 4000rpm and engine light on. 000 Racing Engine, Exhaust, Transmission 14 10-03-2012 07:36 AM
