Old 10-08-2013, 06:33 PM   #1
samuel1990
Drives: 2013 scion frs
tinted taillights, clear coat?
i used rustoleum tailight tint, just wanted to what kind of clearcoat would be a good match for them
samuel1990 is offline   Reply With Quote
Old 10-09-2013, 07:44 PM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I would stick with same manufacturer, so rustoleum clear.
gdrider77 is offline   Reply With Quote
Old 10-10-2013, 03:01 AM   #3
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
spraymax 2k (only 24hrs pot life after activated)
expensive but worth the premium.
$25/can
hanabie is offline   Reply With Quote
Old 10-10-2013, 03:02 AM   #4
hanabie
hanabie's Avatar
dont forget to wetsand and buff
Old 10-10-2013, 01:47 PM   #5
samuel1990
what grit should i get for the wet sanding
how many coats of clearcoat should i spray on?
Old 10-10-2013, 01:54 PM   #6
hanabie
hanabie's Avatar
Id say 1500 -2000 grit. I'd do at least 3 clear coats. If you see any cloudy finish, wetsand it before you put another coat on. You would eliminate any imperfection which will build up later.
You could do 5 clear coats. As you are wetsanding, you are gonna remove the clearcoat anyway. So more coats are good but not too much.
Also, let it dry before you wetsand. You might create crease if you do while the coats are still soft. Water is fine for wetsanding. No need a special soapy solution.
Another tip, check your rattle can nozzle. Some nozzles are loose. Return that and get a new one.
Clear Coat sierra Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-28-2013 10:21 PM
have you tinted or clear bar your 86 at Auto-Links? chenshuo CANADA 2 01-21-2013 09:44 AM
Clear Coat Help Mr. J Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 12-28-2012 10:22 AM
Red tinted taillights FreedE Cosmetic Modification (Interior/Exterior/Lighting) 16 07-24-2012 03:37 PM
Got my BRZ tinted and clear bra done (Bay Area) wrxneffect Southern California 18 06-09-2012 11:03 PM
