Old 10-06-2013, 10:20 AM   #1
Stone Cold
Drives: 94.Prelude BB3 - 99.Civic Ek9
Aftermarket radio with no sound.
Hi, i just try to change my radio, but there was just one problem with the sound.
There was no sound :-(
I got the GT86 with an option JBL soundsystem.
I now its because of the amp. but how can i bridge that, that it works.
does anybody has done that, or are there some cable connectors for that.
Thanks
Stone Cold is offline   Reply With Quote
Old 10-06-2013, 08:43 PM   #2
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Sounds like you may need a harness to go from the preamp outs of your head unit to the jbl amp.
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 10-06-2013, 11:39 PM   #3
captain_jack
captain_jack's Avatar
Thanks
Assuming a few things as there isnt enough info. I assume you have the right harness, however you dont bridge the it. It needs to be turned on just like an aftermarket amp. Try hooking up the power ant/ amp turn on wire. That will be the blue with white stripe of aftermarket radio to the blue wire on purchased wire harness, it may be the same color as new deck. Without this wire hooked up the amp wont produce sound.
Now the us version is different however the toyota jbl system needs a special adapter such as the Metra TYTO-01. If you have this harness my advice stands if not you may need this piece.if you could take a picture of what you have i can more helpful specifically pictures of new decks harness,and aftermarket harness as well as vehicles plugs.
sent from your mom
Old 10-08-2013, 02:59 PM   #4
Stone Cold
Its like you said some stuff was missing, i need that interface but i need to buy it from the usa. im waiting for an message from the shop, do the international delivery.
Thanks for the help
The Following User Says Thank You to Stone Cold For This Useful Post:
captain_jack (10-08-2013)
Old 12-30-2013, 10:22 PM   #5
captain_jack
Hey did you ever get the party you needed and get it working right?
may the schwartz be with you....
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
Retaining Factory BT Mic w/ Aftermarket Radio ecko04 Electronics | Audio | NAV | Infotainment 4 04-08-2014 06:22 PM
Best aftermarket In dash radio for scion frs? animal007 Electronics | Audio | NAV | Infotainment 72 02-04-2014 12:55 PM
Help:new aftermarket radio and question regarding speakers FR-Shadow Electronics | Audio | NAV | Infotainment 2 11-04-2012 07:58 PM
Aftermarket 2DIN Radio Install DetroitJake Electronics | Audio | NAV | Infotainment 4 07-08-2012 11:17 AM
