Old 10-01-2013, 04:46 PM   #1
mf0722
Drives: FX35
OEM Audio Plus installation & BRZ trunk liner question
I've heard the OEM Audio Plus subwoofer unit does not fit with the BRZ rubber trunk liner in place. Anyone have a solution to this that isn't simply not using the liner?
mf0722 is offline   Reply With Quote
Old 10-01-2013, 04:57 PM   #2
sparks
sparks's Avatar
I have the trunk mat from a 2008 STI wagon and had to trim mine. The bass unit is a tight fit.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 10-01-2013, 07:18 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I had to remove the weathertech trunk liner completely. I left the Toyota (Scion Mat is for sale in the classfieds) Trunk Liner on top of the tire/tire tools/jack folding cover. It's tight but it fits. I'm sending the measurements and weathertech mat back to manufacturer and asking for a custom one for this application.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-15-2013, 03:28 PM   #4
tonystewart
Weathertech back in
I reinstalled the weathertech mat and with a whole lot of wiggling it fit
Protecting the new Toyota Mat
Old 10-18-2013, 05:10 PM   #5
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Same here, I just cut mine back a bit, works out fine if you plan to keep the OEM+ woofer box...
kludger is offline   Reply With Quote
Old 12-05-2013, 07:38 PM   #6
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
Now that you have an O+ system, does it fit?
nocturne1 is offline   Reply With Quote
Old 12-05-2013, 10:00 PM   #7
mf0722
Drives: FX35
No, it had to be cut to fit.
Old 12-05-2013, 10:34 PM   #8
nocturne1
nocturne1's Avatar
Thanks for the update. Looks like weathertech is the only safe fit without cutting, according to the previous post.
Old 12-06-2013, 05:46 PM   #9
Davesta619
Drives: Brz
Just curious, how easy is it to get to the spare tire with that O+ system installed?
Davesta619 is offline   Reply With Quote
Old 12-06-2013, 06:03 PM   #10
nocturne1
nocturne1's Avatar
Without an all-weather mat, it's easy. Just pop the rear seat down, fold up the left side of the floor, slide the floor to the left, and pull out. It's possible to do without the seat down, but you'll have to bend the floor quite a bit.
On the other hand, if you're changing a tire, what's a few bolts to remove the sub, if necessary?
Trunk Liner developer Cosmetic Modification (Interior/Exterior/Lighting) 9 08-02-2013 04:41 PM
Trunk lid liner marinjim Cosmetic Modification (Interior/Exterior/Lighting) 13 07-21-2013 11:45 AM
Trunk lid liner. CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 20 01-21-2013 01:16 PM
Trunk liner Ryan86 AFRICA 6 11-27-2012 08:24 PM
FR-S / BRZ no trunk liner? R0ME0 Scion FR-S / Toyota 86 GT86 General Forum 76 04-22-2012 09:31 PM
