Master Troll
Drives: 2013 BRZ Limited
Audio Guru help needed
So I am finally ready to start my audio install. A little back ground on me; I used to install car stereo back in the day and plan to do all the work myself. I have been out of the game for a bit so thats why I am asking for help.
I have a 2013 BRZ limited. I am going to use a Kenwood DNX8120 headunit since I can't seem to sell it anyways. I will need to run a GPS antenna unelss I can somehow use the factory one. The same goes for the bluetooth mic. Help here would be awesome. Also, I plan to do some pretty extensive sound deadening on the door and cannot find a thread where someone did so with corrugated plastic inserts and alot of really nice custom touches. So inout on sound deadening is apprecaited too. I have a JL XD400w 4 channel I plan to run the doors and dash speakers on and leave the rears on headunit power. I would like to go with a quality Hertz or JL audio componant set and some decent 4" speakers in the dash as well. Speaker suggestions are welcome. I will be getting a JL audio XD600 for the Sub and going with a JL audio 10W6 sub in a custom passenger side corner box. Thanks for reading and any input you can provide. CLIFF NOTES: Can you use factory GPS and bluetotohm ic with aftermarket HU? Speaker suggestions for doors and dash? Sound deadening advice? |
DADA
Drives: 2013
You should be able to just splice the gps and mic wires into the HU wire harness, provided it does have the inputs.
There is a sound deadening thread on here, look for it.. you will find it. So your gonna be running a 3 way component? or a 2 way and mids? I dont see why you would buy a component set and then add mids to it.. I like to keep things the same, so if you are already in the JL scene; stick with it. JL has some decent sets on their catalogue, look up and see what fits your budget and needs. |
#3 | |
ProCrastinationConsultant
that's why i ran peerless mids, dayton tweeters, kicker subs, and alpine amps...
Drives: GT86
If you want to add 4" mids into the mix, then you're going to need either custom x-overs for them or run active with a processor. Unless the amp you choose has a suitable bandpass filter.
Check this thread for ideas: http://www.ft86club.com/forums/showthread.php?t=29027 |
#5 | |
Otherwise just focus on getting some good tweeters and woofers and a sub. It is a big upgrade vs stock. |
Master Troll
After looking at some of the pro audio builds it seems tweeters in the dash and a good set of 6.5's in the doors is what a lot of people are doing. I don't mind sticking to JL for amps because they are small and work great but I want really good sound quality and volume. I would have figured no mids in the dash would take away from the front stage but the pros are doing it so it must work.
Sent from my XT1080 using Tapatalk 2 |
Drives: GT86
Yes, 2-way is considerably easier than 3-way to get right.
#9 | |
Drives: 2013 Subaru BRZ WRB AT
The factory Bluetooth mic is tuned to the factory head unit. You can use it,but it will sound bad on the other end. If you go with the 3-way components and use both the amps crossover and the passive crossover for the components you should be fine. Both Hertz and JL make good components. Listen to them both and then go with what sounds best to you. FYI, I went Hertz Mille 3 PA and have not regretted it one bit. For sound deadening, look at the sticky audio index at the top of this sub forum for some good ideas. Also, diyma forum has a LOT of good info on the subject. |
#10 | |
Master Troll
#11 | |
DADA
Drives: 2013
#12 |
I had gotten my Mille MLK 3 PA for $1600. They are Hertz top of the line components. The HSK 163 set is the High Energy Hertz version of them and it runs around $600. The main reason I went with the Mille was the 6.5" from the set. It's one of the best, if not the best, midbass drivers on the market. After a lot of sound deadening to my doors, I almost did not need a sub.
#13 |
Seems Legit
Drives: Toyota
You can use the factory BT mic, I wrote a DIY on how to do it somewhere. Alternatively, you can run your Kenwood mic to the factory location, unclip the factory mic and mount the Kenwood, no wire splicing needed for that option (I also have a DIY for this).
The GPS antenna doesn't really need to be ran. It can be tucked behind the passenger side dash panels and receive full signal, that's where I have had mine with 0 issues in 4 months.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
| The Following User Says Thank You to ecko04 For This Useful Post: | Thongpocket (10-02-2013) |
#14 |
Berz
| Question for you suspension Guru's | invzabomaster | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-13-2013 05:26 PM |
| Audio genius needed... | Shit Luck | Electronics | Audio | NAV | Infotainment | 36 | 06-05-2013 06:09 PM |
| SoCal Audio Shop Needed | dlux | Southern California | 5 | 05-17-2013 05:24 PM |
| Guru's Ultramarine FR-S Adventure | HillCountryGuru | Member's Car Journals | 10 | 05-01-2013 07:31 PM |
| Legal guru I need an advise | Vino | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 09-13-2012 06:13 AM |
