Old 09-26-2013, 11:54 PM   #1
juanam0909
Drives: scion fr-s
springs first or wheels first ?
my frs is completly stock and im trying to decide what to get first springs or wheels, i was looking at getting 17x8.25 or 18x8.75 but idk what springs to get, i use the car as a daily driver and how would i know if whatever wheels i get will fit after the car is been droped. I was thinking doing "1 .
juanam0909 is offline   Reply With Quote
Old 09-26-2013, 11:57 PM   #2
OrbitalEllipses
Drives: Attitude
Tires first.
Old 09-27-2013, 12:05 AM   #3
itwillboost
35r + 35r = 70rr ?
itwillboost's Avatar
Drives: Subaru BRZ Time Attack S13
Tires, and springs suck on the stock struts. Sadly there are no good springs imo that really match the stock struts, and that is not because of lack of r&d but rather the stock struts are just optimal at factory height.
itwillboost is offline   Reply With Quote
Old 09-27-2013, 04:00 AM   #4
SurfAndSand
8SiX
Drives: FRS 10series
Get tires or tires/wheels first. A lot of articles out there show that the twins can handle more grip out of the box pretty easily. About all you want to go on stock power is about a 225/45 tire to make the most out of the car and still maintain the "balance".
I'm only a bench racer though - but I read a lot.
SurfAndSand is offline   Reply With Quote
Old 09-27-2013, 08:40 AM   #5
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I got 4 of 18X8.5 +44 rims, 225/40R18 Square wheels first.
And the height of my car change a little bit. At least it looks higher. The diameter of my new wheels are about 0.5 inch bigger than my old one(I dont think u can feel any difference). so the car should be a little bit higher(~0.25'').
However, those new wheels also clean the gap under the fender a little bit(~0.25'').
I hav a five axis body kit, so I do not want to drop too much. Otherwise I may dogleg on my driveway everyday. So I plan to drop it by about 1''.
Because of the bigger wheels, the 1'' drop can clean the fender gap as well as a 1.25'' drop (Actually may looks like a 1.4'' drop). And the front bumper wouldn't be a lot lower than stock, but looks much better.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-27-2013, 11:56 AM   #6
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
This is my thinking exactly since I have the 5axis kit also. What springs were you going to go with? I was thinking either swift or hotchkis but not too sure how much they vary in handling.
Ryuu0u is offline   Reply With Quote
Old 09-27-2013, 12:19 PM   #7
kALMIGHTY
Drives: TRD Ultramarine '13
If you go the route of getting new wheels first, and then springs, go for the TRD springs IMO. Keep your strut warranty, plus TRD springs are only going to be around the $250 range, so very competitive pricing from TRD for a change. They'd drop close to an inch, which will be the perfect setup from there on.
Old 09-27-2013, 01:06 PM   #8
Figo
Figo's Avatar
I ordered KW V3, should be here next week. swift FR-S springs are good if you want a tail happy car. If planted is wat u want, I will recommend RCE yellow.
Old 09-27-2013, 01:08 PM   #9
Figo
Figo's Avatar
Can we order TRD now? would u plz give me a link?
Old 09-27-2013, 01:23 PM   #10
kALMIGHTY
PTR07-18130.
That's the part number for the TRD springs. Call a few dealers around you to see if they can get you the springs. I don't think they're available yet but a few people here on the forums have pre-ordered them and they've been told it's going to be $208 for springs alone and $370 for springs AND alignment.
Old 09-27-2013, 01:41 PM   #11
Figo
Figo's Avatar
sounds cooler...lol...so that might be the best choice.
PTR07-18130.
Old 09-30-2013, 07:50 AM   #12
Intake
BRZ
Intake's Avatar
What would you guys recommend for a simple 1 inch drop and comfy ride?
Intake is offline   Reply With Quote
Old 09-30-2013, 09:16 AM   #13
Figo
Figo's Avatar
Lowering springs.
Old 09-30-2013, 10:13 AM   #14
Intake
BRZ
Intake's Avatar
Lowering springs.
Any recommendations? Thanks!
Stock Wheels on Tein Springs: Camber? Ammonia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-30-2014 06:30 PM
Springs? What wheels/tires, do you rub? ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-17-2013 06:03 PM
Wheels or Springs? ChandlerSwyng Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-26-2013 09:32 AM
Anyone have pics with eibach lower springs and stock wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-20-2013 04:24 AM
Coilovers vs. Springs and aftermarket wheels. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-01-2012 12:47 AM
