Pegasus White
Drives: 86
Lose of acceleration over bumps
Hey,
Has anyone else noticed when going over bumps that you lose acceleration? I can sit there and watch the rpm drop and the sounds of input decrease.
Driving: Pegasus White Manual GTS 86.
Drives: 2013 FR-S whiteout
Thanks
lol, is this serious?
Just think of what a bump is. The wheel is losing decreasing or even becoming disconnected with the road surface. Less traction or no traction will result in wheel spin which is increasing revs with no apparent increase or even a decrease in road speed. Furthermore, think about going over a bump full throttle, the drive wheels leave contact with the road, the engine speed increases, and then suddenly they are again in contact with the road at a sudden increased speed. Do you think that is good for any part of your drivetrain? I think you shouldn't be complaining about decreased acceleration over shit roads, but rather being less aggressive with your right foot. If you want maximum acceleration on bad roads you should look at something more rally oriented and not something like a sports car. |
Add lightness!
Drives: 17' WRX
It's traction control going crazy. If you turned it off, you'd get some interesting wheel spin instead of power cut.
Unless you're at WOT it's essentially impossible to hold a constant throttle input over bumps too, mostly likely you'll back off the gas accidentally.
If it's WOT, it's 99% sure to be TC cutting in as the rear wheels get light.
#6 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Drives: Sterling Silver BRZ
Are u 12?
| Front suspension squeak going over bumps | Gords_zenith | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-19-2017 09:57 AM |
| New manual driver - SPEED BUMPS! | eifer | Engine, Exhaust, Transmission | 47 | 06-16-2015 01:27 PM |
| speed bumps | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 03-05-2014 10:34 AM |
| Did I Just Lose $90? | larryt1026 | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 08-10-2013 08:54 AM |
| speed bumps | jmaryt | BRZ First-Gen (2012+) — General Topics | 15 | 01-20-2013 02:48 AM |
