Drives: 86 Raven
17 x 9 + 42 on 225/45/17
do you think this set up will have issues on rubbing on the spring perch?
Drives: Some rust bucket
Drives: 86 Raven
1337
Drives: 2013 BRZ WRB S/C
Those tires are stretched for a 9", if that's what you're after then okay. With that small of a tire you should be okay. It will be close, depending on how much camber you plan on running. If you rub, then dial some camber out with camber bolts.
Drives: FRS(sold), AP2, R35, FJC, ED9
you will be fine with that setup. et45 and 245 tires still clear. if you get camber bolts then you might run into some clearance issues with anything more than -1 degree of camber.
check this thread http://www.ft86club.com/forums/showthread.php?t=46733 |
