Old 06-19-2013, 05:14 PM   #1
brillo
Drives: 2013 Firestorm FR-S
White line KCA434 front lower control arm bushings
Anyone installed these yet? The front lca bushing is a odd spherical bushing? that my mechanic says is prone to early failure in other cars he has seen. Figure these should improve the steering response as well.
Curious for feedback from anyone who is running them.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-19-2013, 05:52 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I'm running them but no track days on it yet. Only one autox session. I have all of the Whiteline bushings on and their sway bars as well. I didn't really notice much if anything with those bushings, but like I said I haven't been to the track. I have noticed a positive difference with their rear sub-frame inserts, differential inserts, and trans mount. My build thread has info on what I've done to my car if curious. I'm thinking those bushings wouldn't yield too much of a difference since the stock ones were brand new. If the stock ones were old and used up then I'm guessing I'd notice more of a difference with those bushings. Regardless my car feels very planted, stiff, and tight, insert other similar adjectives here...
stockysnail is offline   Reply With Quote
Old 06-20-2013, 12:42 AM   #3
whataboutbob
AutoX-10/10ths every run
I've been running the bushings on my car for nearly 6 months. 12000+ miles, a dozen or more AutoX event days, NO issues.
Build thread:Here
Old 06-20-2013, 01:22 AM   #4
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I have them, feel great. I changed them with the WL castor bushings, rear upper control arm bushings and steering rack bushings.. so all a contributing factors for the better feel. But as others have said, the difference won't be so great as you arecoming from fresh factory bushings that have yet to break in.
OjiGeorge is offline   Reply With Quote
Old 05-23-2015, 09:08 PM   #5
brillo
I'm getting ready to install the KCA434's on the front LCAs later this week (rented a bushing press kit) and I'm curious, for those that installed them, does the urethane bushing rotate in the stainless housing? (I haven't received them yet).
I know you need to orient the dimples towards the inside of the car per the whiteline instructions but I'm worried about the precision of the alignment of the dimples.
Old 08-02-2015, 11:40 AM   #6
s0sl0w
Proud of Boxer
I would also like an answer to this question.
s0sl0w is offline   Reply With Quote
Old 08-02-2015, 12:37 PM   #7
kingkenny
Drives: 2014 Toyota GT86
No ! I was try to adjust it but couldn't , not without taken the arm off. But mine is super pro , look very similar to whilteline .
kingkenny is offline   Reply With Quote
SPC Lower Control Arms(Old and New) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-10-2017 09:58 PM
ROBISPEC Front ADJUSTABLE tubular lower control arms robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 04-05-2015 09:36 AM
WTB: FRONT LOWER CONTROL ARM (PASSENGER SIDE) Filipino Royale Brakes, Suspension, Chassis 0 04-20-2013 06:38 PM
Front Control Arm Bushings. feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-02-2013 05:35 AM
