Drives: '13 black BRZ MT
Can I drive with 29psi in my tire
My tires are at: 29, 30, 31, 32 psi respectively and use nitrogen.
From my understanding, only dealerships offer nitrogen for tires. Is it safe for me to drive 10-15 miles to go to the dealership? Does my warranty cover nitrogen to inflate my tires at the dealership? |
Drives: Attitude
#3 | |
Drives: 2013 FRS Asphalt
Ok you are fine. Dealerships are not the only ones. Most tire shops have them. do not freak out warranty is fine. You can even put normal air into the tires. I know its crazy but its true.
2013 Scion FR-S AT Picked up 5/30/2012
Drives: 2013 FRS
This forum. I can't even...
Sent from my SGH-T999 using Tapatalk 2 |
29PSI is totally fine just don't be doing any high load turns as you will roll those tires over on the side wall much easier.
i'm sorry, what?
Drives: Canada
Drives: 2003 Subaru Outback
15 miles is ok. Once you hit 16 your car will explode.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
i'm sorry, what?
Drives: Canada
NO ONE, ever, will guarantee or warranty you the pressures in your tires.
And while your tires come with low pressure indicators, you should MAKE IT A HABIT to inspect your tires occasionally by using a tire pressure gauge. Nitrogen or Air don’t make a difference, for everyday driving you’re not gaining anything by using nitrogen. Use a normal compressor to pump it up and call it a day. Pressure differences across the tires don’t make much of a difference for daily commuting either, but generally keeping them uniform is good practice. Welcome to the world of car ownership… it's a sad day in panda land that you are one but I’m sure as hell glad that you’ve come here with questions.. I suggest you ask a lot of them any time something comes up with your car. And don’t go to the dealership… for anything.
Hail Magnet
The atmosphere is 78% Nitrogen, so really, all our tires are filled with (mostly) Nitrogen.
TL: DR--Don't waste your money getting nitrogen fillups. There is no benefit. ![]() P.S.--you're fine. Just go top off your tires. No warranty concerns, just increased tire wear. |
#10 | |
NASA SpecE30 Racer
No. I would instead buy your own air compressor and add some 78% nitrogen air to get the tires back up to 35 psi cold.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#11 |
Drives: WRB BRZ
Nitrogen tends to maintain pressure better over time and no influence by temperature, so a track situation, the benefits are better exploited. However, for normal daily driving you are better off using regular air. If you do not have an air compressor, you can fill up at any gas station. You won't have to worry about finding a shop that can fill.
But keep in mind, once you introduce air to a nitrogen fill you will need to have the the wheel and tire combo reprepped if you go back to nitrogen. They will need to completely remove all the air and then refill with nitrogen. They will charge extra for that.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#12 | |
Hail Magnet
#13 |
Drives: '13 Argento 6MT FR-S
Go to Costco - free nitrogen. The station is usually situated right outside their Tire Service area.
#14 |
When we took delivery of my wife's CR-V the dealership had done the Nitrogen trick. I was happy enough with the deal we got not to make an issue over their little trick to get some more money out of our pocket. The few times we've had to raise the pressure in the tires I just use my home air compressor. Nothing will be harmed by mixing the two.
| WTB One (1) OEM Tire | Trojan_SC | Wheels and Tires | 2 | 05-07-2013 03:59 PM |
| Saturday 3/23 DRIVE: Last chance to drive "The Most Dangerous Road in California" | PMok | Northern California | 173 | 05-02-2013 02:11 PM |
| TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? | No5ki | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-06-2013 08:30 PM |
| HELP...Drive Shaft/Rear Tire Shutter | UM FRS | Issues | Warranty | Recalls / TSB | 11 | 09-05-2012 11:14 AM |
| Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 36 | 12-07-2011 03:13 PM |
