Old 09-14-2013, 08:02 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
$42 for wheel studs, and they seem to work fine.
[ame="http://www.amazon.com/BRAND-EXTENDED-m12x1-25x50-Subaru-Imprezza/dp/B00DV1D3K4/ref=sr_1_fkmr1_1?ie=UTF8&qid=1379203119&sr=8-1-fkmr1&keywords=arp+wheel+studs+wrx"]Amazon.com: BRAND NEW Gold Pin Wheel Studs 10pcs 50mm LONG EXTENDED WHEEL STUD BOLT KIT m12x1.25x50 Fit Subaru Imprezza WRX STi K14.3 A01: Automotive[/ame]
Installed these today, and they installed perfectly. Some people had been complaining about studs being to easy to press into the hub, but these have the same diameter as the ARPs, and took some muscle. I fit a 20mm spacer on with them. We will see how they hold up, but they seem legit.
EDIT: Here come the pics
Old 09-14-2013, 09:40 PM   #2
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
Any pictures?
Trackdaynitis!!
Alain is offline   Reply With Quote
Old 09-14-2013, 09:42 PM   #3
ML
ML's Avatar
Not from the install today. I'm finishing up the fronts tomorrow, so I'll take some pics then.
Old 09-15-2013, 02:07 PM   #4
ML
ML's Avatar
added pics
Old 09-15-2013, 02:23 PM   #5
Alain
FRSKEE
Alain's Avatar
Looks good!!
Old 12-08-2013, 10:49 AM   #6
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Nice! Those spacers made a huge difference. Thanks for posting pics. I've been curious what black wheels with a polished lip looked like on white. I went with all black wheels, but I've been debating on buying a different set with a polished ring now.
ericmpena is offline   Reply With Quote
Old 12-08-2013, 11:22 AM   #7
ML
ML's Avatar
Thanks, they did make a big difference! I plastidipped those rims last week, and I like them a lot better.
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
