Northwest AK, ID, OR, WA
Old 09-13-2013, 03:41 PM   #1
JRTritsch
Drives: 13' FRS
OE tires for portland winter
Should I be looking for some all seasons or will the stock tire suffice save a couple days? I just moved here from Texas, and while anecdotally I have heard about the winter, I've never experienced it. I'll be driving the car all winter but only in heavily travelled roads in portland/beaverton/hillsboro area.
btw I'm new to the area but not winter driving, I drove a miata through several wisconsin winters. Best winter car ever.
JRTritsch is offline   Reply With Quote
Old 09-13-2013, 05:15 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
There is no winter here, only rain. Stock tire will be more than adequate, unless you are planning trips up to Mount Hood.
Decay107 is offline   Reply With Quote
Old 09-13-2013, 05:37 PM   #3
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
I've read and experience that the stock tires lose quite a bit of grip when the temps are below 40ish degrees. Which, depending on when you drive, means from December through February.
Here is my winter setup:
http://www.ft86club.com/forums/showp...3&postcount=57
WRB-DZA-BRZ is offline   Reply With Quote
Old 09-13-2013, 06:43 PM   #4
wheelhaus
wheelhaus's Avatar
The tires do fine in the wet for the most part, but when tems approach freezing, they harden and lose a lot of grip. If they use mag chloride or other liquid formulas to prevent the roads from freezing over, it'll be even worse. Definitely avoid snow and ice. Yes you can still get around, but you'll be at the limit of traction by simply moving. I've been driving on snow for nearly 15 years (Ohio and Colorado) among 8 different cars and dozens of tires, and these tires gave me the biggest scares. I immediately ordered a set of snow donuts.
If the roads only get wet and rarely snow pack or freeze you might be fine; be careful and keep an eye on temps and road conditions and make your best judgement.
wheelhaus is offline   Reply With Quote
Old 09-13-2013, 08:40 PM   #5
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
You'll be fine, but if you had the money to do it I'd put on some winter tires. Better safe than sorry.
sent from my locker... help!
Freeman is offline   Reply With Quote
Old 09-14-2013, 01:49 AM   #6
humfrz
I'm up here just south of Seattle and have the same decision to make. But, since I'm retired, I don't have to go out on the few bad road (snow/ice) days that we do have. I can wait till the wife gets home with the FWD car.
My last car was a Miata with "summer" tires. They were down right dangerous on snow ....
If the FR-S, with summer tires, is your only form of transportation, and you have to drive it every day, I recommend you invest in a set of all season tires ....
humfrz
Old 09-14-2013, 01:14 PM   #7
JRTritsch
Drives: 13' FRS
Thanks for the input. I will drive to work during the week but we have another car that will be the family hauler. I'll give it a shot with the OE tires but if it starts to get ugly I'll just order up a spare set from Tirerack. I hate the idea of basically throwing away the OE tires and I already plan to replace them next spring with a proper summer tire.
Old 09-14-2013, 01:17 PM   #8
JRTritsch
Drives: 13' FRS
humfrz
I once was a bit impatient in the spring and mounted my fun tires (azenis) in march. Drove around with the top down on a 70 degree day, parked, came out and found an inch of snow on the ground. That was a scary drive home. But with some good tread the miata is a hoot in the snow and very controllable.
WTB: winter tires abutterman Want-To-Buy Requests 0 09-10-2013 09:57 PM
Winter and beyond Detailing in Portland OR!! Group buy/discount!! BRZPDX Northwest 12 03-26-2013 11:49 PM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
Winter tires axss Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-29-2012 12:09 AM
Cheap low mile FR-S factory wheels and tires for sale!-Portland OR FRES86 Wheels and Tires 1 09-04-2012 07:04 PM
