Old 09-13-2013, 11:25 AM   #1
Skyllz
Drives: Something fun.
16x8 et48 with a 245, yea or nea?
I got a lead on some very cheap(6 wheels also) Rota Slipstream 16x8 et48 with some 245/45/16 on them. Used on a WRX previously. Tire size thingy tells me it's the same diameter than the stock wheels/tires i'm running except much wider... I'd probably replace the almost dead tires with some RE11s down the line, available in that size. Those would probably be track only wheels/tires, I may even go with Hoosiers on them.
I'm sure it's ok on the fender side but will it clear the suspension?
Thanks
Skyllz is offline   Reply With Quote
Old 09-13-2013, 07:05 PM   #2
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Probably gonna hit the stock struts especially if you have any negative camber. The wheels may be ok with 225 tires but I'm not sure. If you have coilovers they should work.
FastLane1000 is offline   Reply With Quote
Old 09-13-2013, 08:10 PM   #3
xwd
I don't think it would fit without at least a small spacer. I ran 245/45/16 Hoosiers in the past for autocross but I don't think I would put that wide of a street tire on a 16x8 rim or even a Hoosier for track use. You would be better off with a 225 which would likely fit without any issues.
Old 11-18-2013, 08:07 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
@Skyllz, did you end up getting these?
Old 11-23-2013, 12:03 AM   #5
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I want to see them too, but damn its gonna be weird seeing these on something that's not a Honda
dori. is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x7.5 +48 Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 04-12-2021 04:30 PM
Wheel Directory: Enkei Compe 16x8.0 +25 Shit Luck Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 106 09-15-2018 05:52 PM
Wheel Directory: CCW Classic 16x8.5 +14 / 16x9.5 +16 WolfsFang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 04-13-2014 11:56 PM
FT: Enkie Compe 16x8 +25 w/hankook evo's Shit Luck Wheels and Tires 17 07-01-2013 11:21 PM
16x8 Weds Adventure Hase Spec RRnold Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 01-08-2012 01:39 AM
