Old 09-12-2013, 12:47 PM   #1
Barbecue
Drives: Slow
How long to install these bushings?
Roughly how many hours should it take for a good shop to install all these Whiteline bushings? I know some of these can be a pain to install.
WL front lower control arm bushing W0509
WL front caster bushings KCA434
WL rear upper adjustable camber bushings KCA326
WL rear subframe bushings KDT922
WL rear trailing arm bushings W63414
Barbecue is offline   Reply With Quote
Old 09-12-2013, 01:47 PM   #2
frslee
Just drive it
Drives: 13' FR-S
Even though some shops can finish real fast, they'll still charge you by whatever the book hour is... Just pick a nice day and do it yourself.
frslee is offline   Reply With Quote
Old 09-12-2013, 02:05 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by frslee View Post
...do it yourself.
But don't these require a press?
Old 09-12-2013, 02:23 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
oh look at this: a rental from autozone
http://www.autozone.com/autozone/acc...fier=2044_0_0_
supramkivtt2jz is offline   Reply With Quote
Old 09-12-2013, 02:24 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not to put in
taking out the old one will be a fucking pain in the ass for sure though
plus alignment after
the cheapest way to do it is to take everything apart and take the control arms and trailing arms to either a shop with a press, or perform a number of home remedies on a workbench with a vice
these include
a. using a blowtorch to melt the fuckers out (never done myself, watch to not overheat the metal)
b. drill the rubber out (kinda like making a round hole in a board using only a drill)
c. use c-clamps and various diamater cyclinders to create leverage to pop the bushings out
if you can source the right components, i'd go with C, but if it's your first time it might take you some time
assembly is much easier...
either wya this is a ton of work and you're gonna pay for it with either time or money, so choose what's cheaper for you
The Following User Says Thank You to 7thgear For This Useful Post:
whataboutbob (09-12-2013)
Old 09-12-2013, 03:09 PM   #6
whataboutbob
AutoX-10/10ths every run
I did the front LCA bushings with the help of a friend with a press. You should really use a press on this one.
I did the subframe bushings myself in the garage. PITA. Make SURE you don't crossthread the bolts when you bolt it back up.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Calum (09-12-2013)
Old 09-12-2013, 03:32 PM   #7
frslee
Just drive it
Drives: 13' FR-S
If you have a secondary car, then I'd take the control arms and take it to local shop with press. I doubt they'll charge whole lot. Might get some wacky alignment right after installation, but take it for alignment asap! would be my choice.
If there's no second car... call your friend for a ride
Old 09-12-2013, 04:32 PM   #8
boredom.is.me
Custom User Title
Haha I know what that's like.
solution for the rear = control arms
Old 09-12-2013, 05:15 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by 7thgear View Post
not to put in
these include
This is good advice.
Same here
Absolutely!
The front control arm bushings are pressed in and will require a press with a very specific die to get them out. I tired using a 36 mm socket, not a good idea. Now I'm down an expensive socket because the old bushing is still stuck in the socket. I pounded the piss out of that thing and even with my ford hammer I can't get the damn thing out.
Old 09-12-2013, 07:01 PM   #10
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The UCA bushings are biggest pain in ass and IMO they're very difficult to match cambers to it seems and after some driving they lose their settings to I've noticed. If you haven't bought em I'd avoid em and do LCAs and toe links but hey if you have a good shop and patience and money or time on labor go for it.
Old 09-12-2013, 09:58 PM   #11
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
The subframe bushings have been sitting on my garage floor for months now. I'm still waiting for them to install themselves.
neurokinetik is offline   Reply With Quote
Whiteline Rear Camber Bushings (KCA326) Install Tips davtbaum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-15-2013 11:48 AM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
BUSHINGS & SUSPENSION HORSEPOWER DIRECT Brakes, Suspension, Chassis 2 04-22-2013 10:21 PM
STX bushings? -max- Tracking / Autocross / HPDE / Drifting 2 10-07-2012 02:42 PM
Anyone around Long Island,NY wanna do a Viper install? hansthegerman Electronics | Audio | NAV | Infotainment 11 08-01-2012 01:51 AM
