Drives: Firestorm FRS
STX bushings?
Looks like I might have some spare cash coming up. Currently have KWs, wheel/tires, muffler delete, whiteline rear camber bushings.
Wondering what's are some key bushings to replace to stay legal in STX. Rear subframe bushing are on my list. What else should be? |
Conedancer
Drives: 2013 Subaru BRZ SWP
engine/tranny mounts...
Rear Subframe.. Control arms bushings Sway bar bushings Not sure what else but those are the ones I will be finishing up on.. ![]() Hope that helps.. Kartboy Power Flex Whiteline and STi are the manufacturers that I know of. I have some of these done already.. ![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
Curious cat.
Drives: 86 GT base M/T - Red
Can't help you on STX legality but AFAIK the bushings out there include:
- Whiteline rear camber correction bushings (see you've got those already) - Whiteline rear subframe lock down bushings (good call; I'm getting those too). - Whiteline positive shift bushings - AVO turbo world front LCA bushings - AVO turbo world front rear *caster* adjustment bushings. In their thread on their RCE Yellow review AVO indicated that their front bushings reduced a little slop up there that emerged after installing the springs, and a little more caster can't hurt. I'm also getting all the Whiteline bushes for the rear to correct my rear camber post-coil over install and to lock the drivetrain and rear end of the car down a bit. Considering doing the AVO bushes at the same time. Haven't looked at swaybar links yet. I reckon that all of the above bushings are worth it if possible since they seem to correct weak areas of the car. On the other hand I could be wrong since the car seems to be designed to work with bushings flex? My 2c. Interested to hear what others think!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| Urethane Sway Bar Bushings? | phm14 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-16-2013 10:32 PM |
| ++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ | genometuning | Transmission and Driveline | 4 | 10-12-2012 09:23 PM |
| ***MEGA THREAD*** Shifter Bushings | Shift Knobs | Clutches | Flywheels | Dif Covers | FT-86 SpeedFactory | Transmission and Driveline | 1 | 07-26-2012 08:46 AM |
