Old 09-11-2013, 02:41 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
MFactory LSD's - Photo's Inside
We got every MFactory LSD in the other day to stock for racers out there like us. Yo worked his magic and shot some photos as well, which can be seen below.
MFactory offers great Final Drive Gear options and also LSD's now for the FRS/BRZ. We run their 4.67 Final Gear in our Vortech car and also have run their LSD's in endurance cars we have raced in the past. Made sense to grab one for the Vortech car as well as we finish out 2013 and think forward to 2014.
They offer a 1 Way, 1.5 Way, and 2 Way Metal Plate LSD, and also a Helical LSD that fits in the BRZ and FRS.
First Up is the Metal Plate style LSD's.
Through the smooth and constant distribution of power to the wheels, the MFactory Metal Plate LSD puts the power-to-the-ground and maximizes your vehicle's traction where conventional Torsen LSD's fail. Available in 1.0 way (Acceleration Only), 1.5 way (Acceleration/Deceleration) and 2.0 way (Acceleration/Deceleration). All MFactory Metal Plate LSD's are set at 60% Lock for Street/Track usage.
- Made from imported Japanese Steel
- Forged and Cryo-Tempered for unsurpassed toughness
- Advanced Shot Peening technology increases surface hardness
- Only the highest quality Brighton-Best Hardware is used
- Coil Spring preload system ensures minimal power loss and maximum response
- Lower initial pressure ensures maximum durability and chatter-free operation
- Fully rebuild-able with adjustable lock (60-100%) and option of different cam type
- The 1.0 way cam type provides the option to adjust for 2 distinct levels of initial torque transfer
Next is the Helical
Gain a prominent advantage over the competition with the MFactory Helical LSD. Through the smooth and constant distribution of power to the wheels, the MFactory Helical LSD puts the power-to-the-ground and maximizes your vehicle's traction. A must for any RWD race car, be it Street, Strip or Track!
- Designed to withstand the extreme shock loads of competition-level Drag Racing - Advanced gear geometry designed using industry-leading software puts more power to the ground
- Maintenance-free Gears eliminates the need for special fluids & rebuilds associated with plate-type LSDs
- Lock-free operation ensures no adverse affect to steering response
Once we get some time to install on of these in the car we'll post up our feedback. We're headed to the track on the 21st to get some base lines without the LSD and then back in a couple weeks later to see how the LSD helps improve those times.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-11-2013, 02:58 PM   #2
mad_sb
Drives: 2013 Asphalt FR-S
how many monies?
Old 09-11-2013, 04:30 PM   #3
FT-86 SpeedFactory
Originally Posted by mad_sb View Post
how many monies?
$740 - $900 depending on the specific unit. Pretty reasonable for an LSD.
Old 09-11-2013, 04:53 PM   #4
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Do these handle more power than the stock unit? Are there different uses for each type?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-11-2013, 05:06 PM   #5
FT-86 SpeedFactory
The Helical will take 1000HP. The Metal plate ones will take 500HP
Old 09-11-2013, 05:08 PM   #6
Tansey86
Tansey86's Avatar
Damn, I need something that will take 1001 haha.
Is the helical DD'able?
Old 09-11-2013, 08:00 PM   #7
mrk1
Drives: Sterling BRZ Ltd
If I have my facts straight the helical is more DD friendly then a tight LSD type.
Plate/clutch LSD's try to keep the wheels locked until turning the car says otherwise
Helical/Torsen/Gear Type LSD's act more like an open diff when in a straight line, when slip or a turn is detected torque will be shifted as needed. They do get stumped when a wheel leaves the ground entirely.
Torsen is a brand name for a gear type LSD
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Does the Mfactory 4.67 FD directly fit into stock Dif? JiB Engine, Exhaust, Transmission 1 09-03-2013 12:47 PM
MFactory Ring and Pinion Sets JMPoole Engine, Exhaust, Bolt-Ons 14 07-31-2013 12:09 PM
Whiteout - Taillaights Red thoughts (photo inside) Brimford Cosmetic Modification (Interior/Exterior/Lighting) 31 07-21-2012 01:51 PM
