Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 09-09-2013, 07:51 PM   #1
red-frsky
frstrm-frs
Drives: Red FR-S
Angry My worst tire changing experience
I'M HERE TO WARN EVERYONE TO STAY AWAY FROM GATEWAY TIRE next to the Malco Cinema on N Germantown Parkway. Yesterday i went to their store to get my new tires mounted 255/35/18 for the rears and the guy that worked on my car forgot his name cucasian male 5ft6-7in curbed my wheels INSANELY BAD and i just bought them brand new Varrstoen ES1 18X9.5 ill try to post pictures they were plastidipped all black including the lips but you can clearly see the chrome around the whole rims from where he curbed it i had 6 coats of black plastidip on the wheel and he curbed through all of it and the chrome. Anyways i didn't look at them until after work which got me very upset that my new wheels was HORRIBLY DAMAGED however today on my day off as i tried to take my tires off to inspect the damage and try to repair my wheels, i had a very hard time getting my lugnuts off with my breaker bar. The lugs are SR48 Extended Lugs and i took them off MULTIPLE TIMES before with little to no effort however this time only one or two came off easily the rest are glued to the studs and i finally determined that the guy who worked on my car used a high power impact gun to put my lugs on instead of hand tightening them then torqueing them down like the manual says to do which stripped almost all of my lugnuts. Right now my rear tires are stuck to my poor frs unless i break the lugs off with the studs which means ill have to replace all of the rear studs for my car and buy a new set of lugnuts as well. I'm going to go and file a complaint to them tomorrow after i get out class but right now 3-4 lugnuts are stripped on each wheel and i have no way to take them off ill let gateway handle it tomorrow. From now on i'm not trusting any local shops with my car and taking it to my friends shop that i know have a great reputation with customers even though its 20-30 mins away instead of crap shops like gateway that are next door. So be warned this is my warning and my experience with this tire store i'm going to update tomorrow on how my claim goes for my wheels, lugs, and studs i paid $600 just for the rear wheels thank God i didnt change out the front or i would be balling right now. This is my warning to everyon I don't want anyone to go through what i did especially on their brand new FR-S/BR-Z please be warned.
red-frsky is offline   Reply With Quote
Old 09-09-2013, 07:58 PM   #2
bloodsup15
Drives: 2013 Scion FR-S(grey)
That sounds like a nightmare come true. Hopefully you get everything sorted out and some sort of money back from this garbage of a garage.
Sent from my SGH-I747M using Tapatalk 4
bloodsup15 is offline   Reply With Quote
Old 09-09-2013, 08:11 PM   #3
SigmaHyperion
Drives: 2013 SWP BRZ Limited
How do you mount a tire on a plasti-dipped rim?
I can't say I've ever mounted a tire, but I've seen it done enough to think that it would be extremely difficult, if nearly impossible, to successfully mount a tire on a wheel without the machine stripping the plasti-dip all the way around the rim, making it appear "curbed".
I also doubt you will need to replace your studs. It's certainly possible, but just because you can't get them off byhand, doesn't mean the next step is to break the studs off. More likely the lugs were just put on way too tight. Chances are they can juse use the same air tool to knock them loose, and just hand-tighten them so you can get them off. Still not cool at all though. That's why I always keep a breaker bar in my cars -- you never know when you'll get a lug that's too tight or rusted on.
SigmaHyperion is offline   Reply With Quote
Old 09-09-2013, 08:31 PM   #4
utekineir
blowhard
Drives: frs, project forester
utekineir is offline   Reply With Quote
Old 09-09-2013, 08:36 PM   #5
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I'm really surprised these tire mounting places aren't more careful. Are they really not responsible for the damage? I'm sure most people wouldn't notice but still
campy is offline   Reply With Quote
Old 09-09-2013, 08:37 PM   #6
getbent
Drives: 2013 FR-S Blue MT
This. If they were curbed, you would see some serious rash in the chrome. If just the plasti-dip is removed and you can see the original wheel finish then its just that the tire stripped away the plastidip as it was being mounted on the wheel.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 09-09-2013, 08:58 PM   #7
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Need less bold, my eyes exploded after reading
I can sympathise with your situation. I only got a local shop to mount & balance my tires onto the wheel, thankfully with zero incident. I didn't trust any local shop to install my new wheels properly so I invested in a nice tengtool torque wrench (with calibration certificate from sweden!) and did the install myself. When you have high expectations of getting a job done properly, sometimes there really isn't anyone you can depend on except yourself.
enouf is offline   Reply With Quote
Old 09-09-2013, 09:21 PM   #8
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Dude sorry about your lug nuts, but just pushing in / removing the old tire by itself is going to remove that flimsy plasti-dip near the edge, it's a removable product, not permanent.
Rayme is offline   Reply With Quote
Old 09-09-2013, 09:36 PM   #9
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
This
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-09-2013, 09:53 PM   #10
red-frsky
frstrm-frs
Drives: Red FR-S
Um i know he was going to strip the plastidip off i was hoping for that the plastidip was there to protect the actual lip but he curbed through all 6 coats of plastidip AND the actual chrome lip itself thats what piss me off cause they were brand new not even a month old and now they look like crap. I used a breaker bar and was able to rotate all the bolts but the ones that were stripped got harder and harder to turn and eventually stop spinning at all.
Old 09-09-2013, 09:55 PM   #11
red-frsky
frstrm-frs
Drives: Red FR-S
There is deep rashes in the chrome almost all the way around the rims, the right rims has ugly rashes all around but the left is not as bad but still very noticeable.
Old 09-09-2013, 10:25 PM   #12
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
SubaSteve is offline   Reply With Quote
Alignment Shop/ tire changing recommendations HATED1 Northwest 4 09-20-2013 05:03 PM
10 worst car flops 2012 TRD_86 Other Vehicles & General Automotive Discussions 12 12-07-2012 07:40 PM
The worst looking wheels ever? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 10-08-2012 05:52 PM
Top 10 worst car deals, really? drifter BRZ First-Gen (2012+) — General Topics 20 08-23-2012 06:53 PM
