Old 09-07-2013, 02:51 PM   #1
jamesm
vacuum at idle/decel
how much vacuum do your cars pull at idle and on decel? mine is pulling 21-22 on idle and 25 on decel. seems high to me, i can't even find a BOV spring stiff enough to keep it closed (turbosmart only offers combos up to 21inHg). just wondering if something is wrong or this is normal...
Old 09-07-2013, 03:01 PM   #2
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
You might have better luck trying this one in the forced induction section
Zach3794 is offline   Reply With Quote
Old 09-07-2013, 03:11 PM   #3
jamesm
why? i'm asking how much vacuum any other 86 pulls. I don't care if the car has FI on it or not.
Old 09-07-2013, 03:17 PM   #4
pmccut
Drives: Blue Subarus
Only FI guys are watching vacuum/boost. I see -20ish max on idle. I don't think I've seen higher.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 09-07-2013, 03:31 PM   #5
lexusb3
Drives: FRS
agreed! i think im about the same
lexusb3 is offline   Reply With Quote
Old 09-07-2013, 03:32 PM   #6
jamesm
Ah yes, good call. How do I move it? Does a mod have to?
Old 09-07-2013, 06:46 PM   #7
arghx7
Drives: car
At idle, the cams are parked into what's most likely an "underlap" position for combustion stability. This produces high vacuum. Also, a healthy engine with good compression may produce more vacuum than one with poor sealing. Now When you have overlap at idle, like a traditional cammed pushrod v8, you get less vacuum and less stable combustion.
On decel, the engine is free spinning against the restriction of a closed throttle. This also creates a high vacuum. It's pumping air through a very narrow opening.
Basically, this is normal. Now any engine that uses aggressive dethrottling, like a BMW Valvetronic engine, will see very little vacuum at all under any normal conditions. This is because valve events control engine torque output rather than the throttle.
arghx7 is offline   Reply With Quote
Old 09-07-2013, 07:04 PM   #8
Gen
Drives: Scion FR-S
-20 to -21 at idle.
Gen is offline   Reply With Quote
Affordable vacuum? swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 04-02-2014 06:21 PM
Innovate Install Help - Vacuum Routing swift996 Forced Induction 36 07-15-2013 07:47 PM
Vacuum help! Scalzo Forced Induction 6 06-26-2013 02:12 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
WestCoastProjects' Group Buy: Vacuum Infused Carbon Fiber Trunk Spoiler Jason@WestCoastProjects Groupbuys 18 12-20-2012 07:31 PM
