Old 09-03-2013, 12:34 PM   #1
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
Are high beams functional with LED DRL foglight bezel
Thinking about buying a pair of these LED DRL fog light bezel, can you still use your high beams after install? My state N.C. requires hi beam. These are southeast Toyota OEM installed. http://toyotaofmcdonoughparts.net/pr...running-lights
speedy racer is offline   Reply With Quote
Old 09-04-2013, 09:55 AM   #2
jwbrocloud
Drives: Raven MT
Of course... running these should not effect your highbeams at all.
jwbrocloud is offline   Reply With Quote
Old 09-04-2013, 10:18 AM   #3
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Those are not OEM, those or for sure just "dealer installed" parts.
Trust me, I was the first to have these in the US and @F-T sold them and still does for $200 I believe. I also did the DYI for it. Super easy, but your choice.
They keep the OEM high beams. In fact if you only want one set of DRLs I would suggest having the OEM DRLs shut off.
Plus these have 3 different options I bet you didnt know they had.
-Always on high
-Switches from high to low when headlights turn on
-Switches from high to off when headlights turn on
FR-Shadow is offline   Reply With Quote
Old 11-06-2013, 04:19 PM   #4
JR007
JR007's Avatar
Drives: Ultramarine FR-S
-Always on high
Are the 3 different options activated via the on/off DRL switch? Thanks for any feedback.
JR007 is offline   Reply With Quote
Old 11-06-2013, 05:30 PM   #5
FR-Shadow
FR-Shadow's Avatar
No its all dependant on which wire is tapped into the headlights.
Old 11-06-2013, 06:26 PM   #6
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
I run both DRL's and love it this way
eddieEndo is offline   Reply With Quote
Old 11-06-2013, 09:56 PM   #7
JR007
JR007's Avatar
nice drls! which bulbs are you using?
thx!
Old 11-06-2013, 10:24 PM   #8
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
thx!
The bulbs are neat! They are like these led projectors from @KI_ZN6
Old 02-11-2014, 09:08 PM   #9
zoltiz
zoltiz's Avatar
Drives: '17 Toyota 86 6MT
Sorry for the silly question. Day one of the FR-S life.
Does this kit / instructions / help with disabling the OEM high-beam DRL?
Amazing car. Needs about a week worth of work to get it up to snuff, though
zoltiz is offline   Reply With Quote
Old 02-12-2014, 11:27 AM   #10
bmsi30
These are wired direct to a power source so they are independent of your drl. You need to buy tech stream to turn the oem drl off yourself or go to the dealer and have it done. Buy them from eBay. I got my set for 110 shipped from Taiwan took 3 days to ship here. All the vendors are selling the exact same item with different stickers. Check some photos on google and compare the details if you're unsure.
bmsi30 is offline   Reply With Quote
Old 02-12-2014, 12:54 PM   #11
KI_ZN6
KI_ZN6's Avatar
Thumbs up
Thanks, glad you like our G's High Intensity Super White LED DRLs
KI_ZN6 is offline   Reply With Quote
Old 02-12-2014, 02:26 PM   #12
Diode Dynamics
Diode Dynamics's Avatar
Just because products look similar doesn't mean they are the same product.
Nick C.
John C.
Diode Dynamics
Old 02-12-2014, 04:11 PM   #13
bmsi30
The mold cavity numbers are exactly the same for the plastics. The led module numbers are the same. The wiring is exactly the same including all the sticker locations. Unless something is astronomically different inside the control module. I'd say they can't be much different.
Nick C.
Old 02-12-2014, 08:23 PM   #14
zoltiz
zoltiz's Avatar
Thank you for the tip on the eBay source and TechStream idea - dealer shouldn't try to charge for a 2-minute config flag flip, I hope.
LED kit is on the way.
DIY: iJDMTOY LED DRL Foglight Bezel Install JDM FRS DIY (Do-It-Yourself) Guides 17 05-20-2019 01:43 PM
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Exterior Parts - Lighting 16 06-30-2016 04:40 AM
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Cosmetic Modification (Interior/Exterior/Lighting) 0 03-13-2013 12:26 PM
Carbon Fiber Foglight Bezel JonMotoring Exterior Parts - The Rest 0 02-10-2013 04:51 PM
