Old 09-03-2013, 12:11 PM   #1
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
JL Audio StealthBox Owners - Grill Issue
The grill on my StealthBox likes to come off - it seems to fit very tightly. Anyone else having this issue?
I have questions in with the company to see if they have a solution or have heard of this from others.
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01
18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit
H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune
Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits
lsr78 is offline   Reply With Quote
Old 09-03-2013, 12:19 PM   #2
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
I thought I was the only one having this problem.
johnb831 is offline   Reply With Quote
Old 09-04-2013, 10:51 AM   #3
lsr78
My guess is that there is not enough clearance and the sub hits the grill at full excursion. That slim 10 has a surprising xmax.
Enkei PF01
Old 09-16-2013, 11:41 AM   #4
jaymannj
jaymannj's Avatar
Drives: 2013 silver BRZ
aha yea... I have this problem... although it may have to do with how the shop installed it... they used a hanger and drilled it into the trunk so that way it could be taken out if I need to use spare tire.... only problem is that the screws come out which means if I hit a hard turn or a hard bump... my sub ends up on its side... which mayb have to do with the grille coming off...
jaymannj is offline   Reply With Quote
Old 09-28-2013, 04:22 AM   #5
rbizzle004
I have it installed correctly and still have access to the spare tire. I can even put the trunk liner back with some effort without removing the sub and box. No issues w the grill
rbizzle004 is offline   Reply With Quote
Pioneer Premium audio random issue theurbaninja CANADA 28 08-02-2013 06:12 PM
Issue after battery disconnect Audio related. Mako Issues | Warranty | Recalls / TSB 4 07-10-2013 09:29 PM
Stealthbox from JL Audio finally shipping Orlando BRZ Electronics | Audio | NAV | Infotainment 4 06-06-2013 07:07 AM
BRZ Stock Audio Video System / USB Drive Issue Space Boy Matt Electronics | Audio | NAV | Infotainment 0 10-23-2012 01:19 PM
JL Audio Stealthbox hoipong Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 06:21 PM
