Old 09-01-2013, 07:45 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Somethings lose with the suspension.
Basically at 65-70 MPH i get a really harsh vibration when going straight, though when i turn the wheel a little bit it all goes away. Driving around town around 30 MPH i hear something lose/clunking when hitting bumps in the front suspension, and moving the steering wheel left to right when passing the middle creates a noise.
I noticed this after driving a 300 miles straight to Ohio, happened at random and well i drove back with all of this too.
I'm all stock except a Grimm Speed strut tower brace and master brake cylinder brace.
I have yet to take the wheel off. I'm thinking about taking the car to Toyota Friday since i am still under warranty.
Any ideas?
Edit: I should also mention the most important part, the control arm and axle was replaced due to my car being hit, the control arm was bent. No other main suspension parts were replaced.
Old 09-01-2013, 08:08 PM   #2
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
I'm gonna bet your strut tower brace or brake cyl brace is loose
check your lug nuts
448hpsti is offline   Reply With Quote
Old 09-01-2013, 08:53 PM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
check your lug nuts
+ one on the brace .
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-01-2013, 09:48 PM   #4
dem00n
dem00n's Avatar
Drives: Scion FRS
Took all the mods off, they have nothing to do with it.
It's the steering, when i get the vibration on the high way its so exact and precise that i highly doubt it would the dampner or springs.
I'm going to do some more research, if i can at least pin it down to what it can be and i can more comfortable getting it fixed or even fixing it myself if need be.
Old 09-01-2013, 10:01 PM   #5
dem00n
dem00n's Avatar
Drives: Scion FRS
Bascially i have it down to 4 things.
Ball joints
Tie rod ends
Drag link ends
Bearings
Ball Joints are possible but enough to cause a vibration that shakes the whole car? Also, the clunking i get while driving at low speeds?
Tie rods are a good possibility, drag links as well.
It is also possible that the clunking is a whole other problem.
Bearings as well, but wouldn't it be possible for the vibration to be felt at lower speeds too?
God, so many different questions and no pure answer. Its going to be a long night.
Old 09-01-2013, 10:11 PM   #6
chutrain
chutrain's Avatar
Drives: WRB BRZ
Also have the wheels checked for straightness and possibly rebalance. Vibrations can occur at different speeds and go away.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 09-01-2013, 10:14 PM   #7
dem00n
dem00n's Avatar
Drives: Scion FRS
That is also true, even though re-balanced not long ago, a simple bad bump could offset it.
Old 09-01-2013, 10:48 PM   #8
chutrain
chutrain's Avatar
Drives: WRB BRZ
We live in NY, so never rule out a bent wheel or a weight possibly knocked off.
In the garage:
1988 BMW E30 M3
The Following User Says Thank You to chutrain For This Useful Post:
448hpsti (09-04-2013)
Old 09-07-2013, 12:34 PM   #9
dem00n
dem00n's Avatar
Drives: Scion FRS
Update:
Inner tie rod is shot, Toyota is going to replace both sides, under warranty too.
The vibration was fixed with a wheel balance, though the wheel was extremely out of whack, which was odd considering i had one not that long ago.
I'll give a final update once the new tie rods are in, should be next week.
Old 09-07-2013, 12:39 PM   #10
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Sounds like ya might have hit something.
Old 09-07-2013, 02:11 PM   #11
dem00n
dem00n's Avatar
Drives: Scion FRS
Possibly, i'll ask if i can see the old inner tie rod before they throw it out. Might give a clue.
Though only at 25K miles, i'm afraid to what i'll accumulate at 100K.
Old 09-18-2013, 08:22 PM   #12
dem00n
dem00n's Avatar
Drives: Scion FRS
Outer tie rod changed, problem fixed.
Most likely from the accident, no one should be worried.
The Following User Says Thank You to dem00n For This Useful Post:
whataboutbob (09-18-2013)
Old 04-17-2017, 11:03 PM   #13
ymoua4
Drives: 2017 Subaru BRZ
Hey I think i have the same problem as you, was it just the outer tie rod?
ymoua4 is offline   Reply With Quote
How did I lose my crickets? skye67 Issues | Warranty | Recalls / TSB 37 09-28-2013 09:42 PM
Did I Just Lose $90? larryt1026 Cosmetic Modification (Interior/Exterior/Lighting) 30 08-10-2013 08:54 AM
At what milage did your OEM tires start to lose grip? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2013 05:38 PM
BRZ/FRS - when they lose their charm... Marloon Other Vehicles & General Automotive Discussions 51 05-03-2012 09:05 AM
Don't lose hope! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 88 05-18-2011 12:20 AM
