Old 09-01-2013, 12:16 AM   #1
Seungify
Seungify's Avatar
Drives: Scion FR-S Whiteout Automatic
Grimmspeed license relocation issue
So, I recently got the Grimmspeed license plate relocation and I followed their site to install it but I ran into a few issues:
The shaft or whatever it's called that goes into the tow hook area doesn't stop turning like a normal screw is supposed to
And
I noticed that every time I took the car out for a drive, the license plate would be turned around and then I would have to turn it back into its normal position.
This is my first time getting something like this for a car and what not so... What am I doing wrong or is there a fix for this?
Seungify is offline   Reply With Quote
Old 09-01-2013, 12:22 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Tighten it more? I know mine slipped for a little until I tightened the hell out of it. I think it has more threading than we think.
Is it rotating at the actual plate mount or the shaft in the tow hook? And how did you use the spacers (if at all)?
Old 09-01-2013, 12:30 AM   #3
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
What do you mean it doesn't stop turning? You keep turning it until it stops, then you torque it to 45 ft-lb. Make sure you put some anti seize on the threads.
Your plate backing that attaches to the "U" bracket that attaches to the shaft is not on tight enough, so as you tighten the screw until catches the rotate the plate counter clockwise then as you tighten rotate it clockwise. Repeat a few times until its straight and tight, or whatever position you want it then you should be fine. Put some anti seize on the bolt that goes into the shaft that attaches your plates.
btw, make sure that you tighten the screw on your front plates until snug, one of mine fell off when driving.
Hope this helps
The Following User Says Thank You to Wes For This Useful Post:
Seungify (09-01-2013)
Old 09-01-2013, 12:35 AM   #4
Seungify
Seungify's Avatar
Attempted to tighten it but it doesnt stop turning lol... I guess I can describe it as freely spinning?
I think it's the shaft not the mount. After a ride, i look at it and my plate is like vertical and I can't move the plate without making the shaft turn with it.
Old 09-01-2013, 12:42 AM   #5
Wes
Wes's Avatar
Keep turning, it should't just keep going on and on, if so then you may have a problem with it.
Old 09-01-2013, 12:48 AM   #6
Seungify
Seungify's Avatar
Aww man well I guess I have a problem with it because it does go on and on... It make a noise when I keep turning it like it stops turning, "jumps" and then restarts the turning process
Old 09-01-2013, 12:48 AM   #7
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
It is impossible for it keeps turning because the shaft is not thread all the way. It must stop at some point. Unless they sent you the wrong size one.
#944_10_Series_FRS is offline   Reply With Quote
Old 09-01-2013, 12:55 AM   #8
finch1750
finch1750's Avatar
Yeah. At this point contact Grimmspeed. they have great customer service and will take care of this I'm sure
Old 09-01-2013, 12:59 AM   #9
Wes
Wes's Avatar
Yeah, definitely contact Grimmspeed, it shouldn't "jump". I'm sure they will send you a replacement.
Old 09-01-2013, 01:17 AM   #10
Seungify
Seungify's Avatar
Thank you all for the help!
Old 09-01-2013, 01:21 AM   #11
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
For the "jump" I can only assume the threading of that shaft is not correct...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-01-2013, 02:57 AM   #12
nayrk
Drives: 2013 Asphalt Scion FRS
I had that happen to me... I just kept turning and turning without success. I eventually just pushed it in a bit while turning and it eventually threaded tightly. I guess I had too much anti seize on or something... I just installed it this Friday.
nayrk is offline   Reply With Quote
Grimmspeed Subaru BRZ/Scion FR-S :: License Plate Relocation Kit ImportImage Exterior Parts - The Rest 243 12-16-2015 05:08 PM
GrimmSpeed License Plate Relocation Kit Foobar Exterior Parts (Aero, Lighting, Etc.) 2 01-05-2013 01:11 PM
J2 Motorsports- GrimmSpeed License Plate Relocation Kit J2 Motorsports Exterior Parts - The Rest 11 11-27-2012 09:15 AM
License Plate Relocation Kit-Grimmspeed On Sale! SpeedBRZ Exterior Parts - The Rest 1 07-31-2012 04:55 PM
GTA group shipping for GrimmSpeed License Plate Relocation Kit pizzahead20 CANADA 3 06-15-2012 07:14 AM
